MikeDanger
Posted: Mon Jan 04, 2021 1:22 pm Post subject: |
US s2 is 8.0 C:R _________________ It was either this or a giant box of legos |
Posted: Tue Jan 05, 2021 2:41 am Post subject: |
Carrera RSR wrote: | ARP fixings requires ARP grease |
It comes with the studs though..
MLS is probably the better way to go, but I haven’t had any problems with my new stock gasket under ARPs.. Yet..
It’s debatable what one needs to do to the finish on the block deck and head surface in order to use an MLS as they require a certain standard of smoothness/finish..
MLS gaskets can also be bought in many different thicknesses, so you can either retain your stock CR, or raise or lower your CR, depending on what thickness gasket you choose.. _________________ 80 Turbo - Slightly Modified |
Joined: 08 Jan 2010 Posts: 2104 Location: Somerset, UK
Posted: Tue Jan 05, 2021 10:25 am Post subject: |
50RA finish on the surfaces for Cometic. Pretty stock finish, nothing special.
Stock HG don’t last too long on 1.0bar + boost. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
