WTB: NA Alternator Mounts
Post new topic   Reply to topic    924Board.org Forum Index -> Cars and Parts Wanted/For Sale
PostPosted: Sun Jan 03, 2021 2:38 pm    Post subject: WTB: NA Alternator Mounts Reply with quote
Looking for the alternator mounts for a NA. The bracket that bolts to the block is #046 903 143A and the front offset bracket that bolts to the water pump is #046 903 145A.
Mike
'77 924
cricketdesigns.com
Moparboy72
PostPosted: Mon Jan 04, 2021 4:12 pm    Post subject: Reply with quote
Mike,
I have the water pump bracket (046 903 145 A) from a '77 engine. I will send you a photo via email.
Thanks,
Andrew
PostPosted: Tue Jan 05, 2021 12:39 am    Post subject: Reply with quote
Thanks, I found in my stash a back mount(to block) that is cast aluminum, rather than a bent steel bracket, at some point they changed and apparently the front changed at the same time. I'd prefer the older steel bracket. I'm going to try to adapt in a Chevy Denso mini(40a) alternator. My car electrical system is ignition(MSD the wants high voltage) fuel pump and brake lights so the demand isn't very high. I use a size 18 powersports battery.
Mike
'77 924
cricketdesigns.com
Post new topic   Reply to topic    924Board.org Forum Index -> Cars and Parts Wanted/For Sale All times are GMT + 11 Hours
