MOTANUL
Joined: 19 Nov 2018 Posts: 143 Location: ROMANIA BUCHAREST
Posted: Wed Dec 23, 2020 6:21 am Post subject: |
Carrera RSR wrote: | Use Total Seal piston rings.
I have already written to Total Seal. But I did not receive any answer. I later wrote to another member of the sales team - he didn't answer either.
It is possible that the size of the piston on my car is atypical (86.75) and they don't have piston rings for this size.
I managed to buy connecting rod from Romania.
Ref. the Piston rings 86.75:
It is still not 100% clear to me if the pistons rings of the Porsche 924 S2 are identical in size to those of the Porsche 924 S1. I found to buy Genuine piston rings for porsche 924 turbo S2 (86.75 mm).
For main bearings I have: https://www.mespiecesauto.com/en/produit/coussinet-porsche-924-046105501-0406105561-046105591-046198451/
I receive an answer from mittelmotor.de. They have everything (piston rings, connecting rod, main bearings) for 700 euro.
 _________________ 1980 Porsche 924 Turbo (931) diamond silver metallic/helios blue metallic
sold Porsche 924 NA 1979 |
bureau13
Joined: 07 Sep 2017 Posts: 349 Location: South Florida
Posted: Wed Dec 23, 2020 3:50 pm Post subject: |
Maybe a ROW vs US thing? I THINK I read that the US cars had slightly lower compression than the ROW cars, although I don't remember if that were only particular years, or what the numbers were.
MikeDanger wrote: | are you sure s2 is 8.5:1?? thought it was 8.0
944 turbo is 8.5 |
_________________ -----------------------------------------
1982 931
1986.5 Silver 928S
2007 Hummer H3 (Daily Driver)
Past lives (I miss them all):
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
1987 RX-7 Turbo II (Sold)
1985 RX-7 GSL (Stolen) |
Joined: 08 Jan 2010 Posts: 2104 Location: Somerset, UK
Posted: Wed Dec 23, 2020 5:19 pm Post subject: |
MOTANUL wrote: | Carrera RSR wrote: | Use Total Seal piston rings.
Have you pulled the pistons to check size? Usually 86.5 then 86.95
Have checked the bores for wear?
S1 and S2 rings are the same _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
MOTANUL
Posted: Wed Dec 23, 2020 9:36 pm Post subject: |
S1 and S2 rings are the same |
86.75 is my size - repair stage nr.1. An atypical dimension on the verge of extinction.
Bores wear 0.01 mm
S1 and S2 rings are the same: Very happy
After a thorough cleaning, the cylinder head looks like new. The engine block, on the other hand, looks worse - it's very rusty.
