The Green 931 -my first transaxle ever (resurrection thread)
Goto page Previous  1, 2, 3, 4, 5, 6, 7
PostPosted: Sun Nov 08, 2020 8:55 pm    Post subject: Reply with quote
That’s the early set up. Chassis rail mounted as on my turbo. My race shell has the later version as per GT and 944’s
Cédric
PostPosted: Sun Nov 08, 2020 10:09 pm    Post subject: Reply with quote
I helped wrench a bit on a 82 931,it had both the later air blower system and the late sway bar design.
You are probably better of making some adapting yourself, the 944 version is crappy with the flimsy brackets.
kondzi
PostPosted: Thu Dec 17, 2020 6:57 am    Post subject: Reply with quote
Put this car to the freezer until spring. My 1st thing to do is rear torsion bars change. 300lbs spring in the front coilovers and stock on the rear is a no go. What diameter should I go to match fronts? I'm used to do setups with either torsion bars F/R or coilovers F/R but not a mix
Konrad
'89 951 US
'81 931 RoW (TBD)
Cédric
PostPosted: Thu Dec 17, 2020 7:25 am    Post subject: Reply with quote
My 28mm rear bars i calculated to match 350/60 N/mm springs. So without recalculating i would guess around 26-27, i bought the cheap vw ones.
But It depends on many things, what anti roll bars and what tyre widths you use for example.
kondzi
PostPosted: Sat Dec 19, 2020 7:11 am    Post subject: Reply with quote
Thanks Cedric, I will not chase 10ths of second on a lap, so a guesstimate works fine with me I have 19mm adjustable ARB at rear from 968CS. Wheels are 7/17, tires 225/50 all corners.
Konrad
'89 951 US
'81 931 RoW (TBD)
Page 7 of 7
