WTB: Solid Lifters
Post new topic   Reply to topic    924Board.org Forum Index -> Cars and Parts Wanted/For Sale
Moparboy72
PostPosted: Mon Aug 24, 2020 10:34 am    Post subject: WTB: Solid Lifters Reply with quote
I could have sworn there was a link on here in the recent past to a Swedish/Scandinavian site selling solid lifters which fit the 924/931. I have searched a number of times but can not seem to find the link.
Let me know if you can help of if you have a set for sale.
Thanks!
PostPosted: Mon Aug 24, 2020 11:45 am    Post subject: Reply with quote
I think that was Gegge, hidden in a rebuild threat a while back. RD Valve Spring in CA makes both 38 and 38.5 buckets, I'm under the impression that ours are 38.5, could be wrong. I called about valve shims and then asked about the buckets and he didn't have any 38.5's in stock. They make the Lindsey Racing high performance valve springs for the 944 line.
Mike
'77 924
cricketdesigns.com
PostPosted: Mon Aug 24, 2020 12:21 pm    Post subject: Reply with quote
Catcam in Netherlands, Piper camshaft and Newman Cams in UK can make them also. I just bought a Catcam cam, price was good, delivery was about 4 weeks. l
Mike
'77 924
cricketdesigns.com
gegge
PostPosted: Tue Aug 25, 2020 4:09 am    Post subject: Reply with quote
Dirty cheap USD10 a piece:
https://www.acm.se/en/product/valve-tappet-38-5-mm-porsche
Sten Parner retired and sold his company to ACM. These are the exact same as IDEOLA sold a couple years ago.
Carl Fredrik Torkildsen
Cédric
PostPosted: Tue Aug 25, 2020 4:53 am    Post subject: Reply with quote
Oh, so that's where his stuff went. Not exactly great advertising to not even write what car they are made for. What lash caps did you end up using?
PostPosted: Tue Aug 25, 2020 6:55 am    Post subject: Reply with quote
Whats the point of these lifters exactly unless you are trying to build a high rpm engine exceeding the capabilities of the rods even?
They are already solid lifters, and the grub screws are pretty darn convenient..
Cédric
PostPosted: Tue Aug 25, 2020 7:40 am    Post subject: Reply with quote
Well, except for high revving the spm ones at ACM is about a 1/10 of the price of a new stock lifter but sure the adjusting screw is nice but heavy
Moparboy72
PostPosted: Tue Aug 25, 2020 11:06 am    Post subject: Reply with quote
Thank you all for the responses. This is the exact link I was looking for.
gegge
PostPosted: Tue Aug 25, 2020 5:10 pm    Post subject: Reply with quote
IIRC Alfa Romeo was the only brand that used lash caps for 9mm stems. In my 931 head there are Ferrara 7mm valves, no problem finding lash caps.
Coco_Lev
PostPosted: Sat Oct 31, 2020 3:33 am    Post subject: Reply with quote
Has anyone a feedback on the durability of these products?
From my datas, steel has a higher Young modulus than grey cast Iron that means a higher contact pressure. In renault engines there're several failures of this type, because of this kind of material replacement.
PostPosted: Sun Nov 01, 2020 12:12 am    Post subject: Reply with quote
I have the Parner ones in my race car that I bought used from Britain Smith. He really pushed them hard and I haven't been very easy on them and they are doing well. My current camshaft was nitride hardened so probably harder than the buckets. Bucket lifters are very common these days on OHC motors and motorcycles. Ours are unusual due to the size, most of the available ones are smaller in the 26-36mm range. I'd tend to look for an oiling issue first. The surface stresses of the bucket to cam interface opens up the huge subject of zinc in the oil content.
Mike
'77 924
cricketdesigns.com
PostPosted: Sun Nov 01, 2020 4:10 am    Post subject: Reply with quote
Adjusters are a garbage setup unless you have brand new lifters and brand new adjusters (which no longer exist). Otherwise the screws and the threaded holes are too hammered and misshapen to get a reliable lash setting.
My opinion only...YMMV.
gegge
PostPosted: Mon Nov 02, 2020 6:56 am    Post subject: Reply with quote
I have the solids in my DD without any issues. Thay are doing just fine with a 14mm lift race cam.
Post new topic   Reply to topic    924Board.org Forum Index -> Cars and Parts Wanted/For Sale All times are GMT + 11 Hours
