924 Brakes - Master Cylinder?
stan_5150
PostPosted: Mon Jul 13, 2020 7:51 am    Post subject: 924 Brakes - Master Cylinder? Reply with quote
Good day. 1978 924 approximately 76K on it. Last time it had tabs on it was in 2002 and to my knowledge it hasn't been run since then. It was my dads and he always garaged it. Any.....
Brake pedal went to the floor, noticed that there wasn't any brake fluid in the system so I've spent my time bleeding all 4 corners. Fluid pumps, no air that I can tell, but pedal still goes to the floor. I'm thinking master cylinder but if anyone has any suggestions please let this noob know!
Thanks.
PostPosted: Mon Jul 13, 2020 10:34 am    Post subject: Reply with quote
Sounds right..
stan_5150
PostPosted: Tue Jul 21, 2020 4:48 am    Post subject: Reply with quote
Much appreciated! Anyone have a good suggestion for a parts source for a Master Brake cylinder for these? I've seen everything from a $75 rebuilt unit to $750 for a new one. Any/all suggestions welcome. Thanks again.
PostPosted: Wed Jul 22, 2020 12:21 am    Post subject: Reply with quote
Thanks for saving another 924. I've had good luck with rebuilt hydraulic parts.
Brake hoses have a 10 year life, if they are older, you should replace them.
https://www.oreillyauto.com/shop/b/brake-systems-16456/brake-hydraulics-16513/brake-hose-12844/b5f009f547f7/1978/porsche/924?q=brake+hose&fitAttr_10039=Show%20All
https://www.fcpeuro.com/Porsche-parts/924/?year=1978&m=20&e=802&t=6&b=9&d=&v=10&keywords=brake%20hose
stan_5150
PostPosted: Wed Jul 22, 2020 1:16 am    Post subject: Reply with quote
Great suggestions! Time to do some shopping and fixing.
scm924s
PostPosted: Wed Jul 22, 2020 6:37 am    Post subject: Reply with quote
There was a change to the master cylinder about 78/9, the later ones were larger, also did away with the 2 brake light /fluid level warning light switches on the bottom of the m/cyl. At least on the euro spec cars. Early ones appear to be getting harder to find.
1984 n/a Ruby Red Metallic
1988 924S Guards red- sold
1986 924S Guards Red - sold
1984 n/a Black - sold
1980 n/a Le Mans#1 - sold
1980 n/a Le Mans#2- sold
1977 Martini - sold
!tom
PostPosted: Fri Jul 24, 2020 3:36 am    Post subject: Reply with quote
The 78 still used pressure switches...
78 924 NA
5-lug
stan_5150
PostPosted: Wed Aug 12, 2020 11:17 pm    Post subject: Reply with quote
Anyone know where the best source is for a 924 master brake cylinder rebuild kit?
stan_5150
PostPosted: Fri Sep 11, 2020 10:43 pm    Post subject: Reply with quote
Long shot question here....has anyone here used a part number 171 698 181 L Brake Master Cylinder Repair kit on their 924? I found the number here: http://www.924.org/parts/parts.htm but just trying to see if anyone has any experience with that part number. Thanks in advance.
1978 924 N/A
stan_5150
PostPosted: Tue Sep 15, 2020 10:58 pm    Post subject: Reply with quote
Hey all. I found a repair kit online with a part number that ends in a "-181H".
The one on the 924.org parts page is a "-181L".
What does the alpha character in the Part Number denote? Some sort of upgrade/downgrade?
Thanks in advance.
1978 924 N/A
Coco_Lev
PostPosted: Fri Sep 18, 2020 8:43 am    Post subject: Reply with quote
in the catalog it right ends by H letter
here is your kit
https://www.autodoc.co.uk/autofren-seinsa/7875262
stan_5150
PostPosted: Fri Sep 18, 2020 10:01 pm    Post subject: Reply with quote
Many thanks!
1978 924 N/A
