Porsche 924 Racecar Build Thread (AAN Conversion)
Goto page Previous  1, 2, 3, 4, 5
PostPosted: Fri Sep 04, 2020 10:10 pm    Post subject: Reply with quote
Very impressive work!
Really like the diffuser... will be even sexier in carbon..
'79 924 #77 ITB racecar
kondzi
PostPosted: Sat Sep 05, 2020 7:37 am    Post subject: Reply with quote
Really enjoying that metal work (alloy work). Good stuff!
Konrad
'89 951 US
'81 931 RoW (TBD)
Britain
PostPosted: Tue Sep 08, 2020 4:36 am    Post subject: Reply with quote
Few more technical updates for this thread.
We kept having issues with the T3 flange bolts on the cast manifold coming loose and wanted to go with an slightly bigger turbo so I went about building a stainless manifold.
Started off cutting an exhaust flange on the waterjet and then had recessed cut into it on a friends CNC.
Then the cast stainless bends register right into these recesses.
Here is the log part of the manifold completed.
Then the up-pipe to the turbo was fabricated with the WG port.
Here is the manifold with the Garrett turbo hanging off it.
And the new v-band downpipe to go with it.
Britain
The next things to address is more heat management.
First up with another oil cooler to add to the system. Now the oil comes from the engine thru this cooler first and then thru the oil-water heat exchanger. This reduced both the oil temps and the water temps which was the intended result.
Here is the oil cooler mounted off the front sub-frame:
And a scoop that fits flush to the front valance:
Next up was to reduce in intake air temps a bit. This turbo has a wider powerband so we are seeing boost long and therefore increased IAT's.
To start, I purchased a huge Garret intercooler core. This one is rated for 1200hp. The primary purpose for this size core was to get the depth that closely matched the stock unit.
I then proceeded to cut it in half which gave me a core that was 4.5" deep, 7" tall, and 22" wide (the stock 944 turbo core is 5" deep, 5.5" tall, and 18" wide)
Here is the comparison with the end-tanks welded on:
And mounted in the car with the fencing adjusted to match the increased width.
CÚdric
PostPosted: Tue Sep 08, 2020 6:01 am    Post subject: Reply with quote
Nice that you keep updating the thread. Have you though about doing a more ambitious extractor scoop on the bonnet. If you want to improve the efficiency of the radiators?
┤80 924 Turbo
Britain
PostPosted: Tue Sep 08, 2020 8:07 am    Post subject: Reply with quote
Yeah....space is a bit tight, but I am going to make something. There is a balance to ensuring we have ability to address things quickly during the race.
-Britain
kondzi
PostPosted: Tue Sep 08, 2020 8:14 am    Post subject: Reply with quote
I need to master Aluminium TIG welding, that's a must
Tried a bit, but it's quite difficult, or it's just beginners issues.
Good to have friends with CNC capable to shape stainless, anyone with CNC shop wants to be my friend?
Konrad
'89 951 US
'81 931 RoW (TBD)
Page 5 of 5
