Posted: Mon Jul 20, 2020 7:45 am Post subject: 931 S1 vacuum advance/retard.. |
The boost retard line is the one on the backside of the can right? Goes to the brake booster hose/manifold vacuum..
The one on the front goes to the ported vacuum on the TB right?
If so, then why does my idle change if I remove the line on the back of the can and plug it, while my idle does not change if I remove the line to the front of the can and plug it?
Confused..
I figured removing the boost retard line on the backside wouldn't change anything except for on boost, but this doesn't seem to be the case.. _________________ 80 Turbo - Slightly Modified |
kondzi
Joined: 02 Jul 2018 Posts: 143 Location: MZ/Poland/EU
Posted: Tue Aug 11, 2020 8:19 am Post subject: |
Not sure about 931/S1, but I’ve recently had a strong headache from 1986 930 US. This has two vacuum cans - one for boost retard, the other for vacuum advance control with additional idle advance when cold. The trick was there was US emissions system that advanced idle ignition a bit at cold engine by blocking vacuum to the idle can (letting in atmospheric air instead) When the engine warmed up, the solenoid valve opened and a fully functional vacuum advance was operational.
Maybe, but just maybe it’s similar in 931/S1? _________________ ---
Konrad
'89 951 US
'81 931 RoW (TBD)
Posted: Thu Aug 13, 2020 4:17 am Post subject: |
Mine doesn’t have any valves in the middle of the vacuum lines..
I was just trying to figure out a way to stop it from regarding so retardedly much on boost, quick and dirty style.. _________________ 80 Turbo - Slightly Modified |
