NLA: o-ring seal for turbo bearing housing to drain line
Goto page Previous  1, 2, 3
PostPosted: Sun Jul 31, 2011 5:57 pm    Post subject: Reply with quote
oils coming up through the centre of the nut closest to the block??
I'm guessing the o rings are the issue?
also if replacing the seals in situ am I right in thinking you don't need to drain the oil?
PostPosted: Sun Jul 31, 2011 9:14 pm    Post subject: Reply with quote
That's the top seal, the green one pictured earlier in the thread, and it's still available. It's the bottom one, the larger one on the drain line, that is NLA. That top one is going to be an absolute bear to replace in situ.
PostPosted: Tue Aug 02, 2011 12:05 am    Post subject: Reply with quote
OEM seal on left; McMaster-Carr part number 9464K35 on the right (I.D. 25mm x 3.5mm thickness)
And, McMaster-Carr part number 9464K35 installed:
stevekat
PostPosted: Tue Aug 02, 2011 6:37 am    Post subject: Reply with quote
Looks pretty good. Photo from the side would be interesting to see seal above machined surface...
K-Roll931
PostPosted: Fri Jul 24, 2020 12:41 pm    Post subject: Reply with quote
Hate to revive a nine year old thread. But as I've recently bought a second K26 for rebuilding, and knowing this part is probably still NLA, I'd love to know what conclusions were drawn from this, if any?
'80 931 M471 - Dolomite Gray -> Monaco Blue
PostPosted: Fri Jul 24, 2020 12:46 pm    Post subject: Reply with quote
Works fine for me!
K-Roll931
PostPosted: Fri Jul 24, 2020 12:52 pm    Post subject: Reply with quote
Works fine for me!
http://www.mcmaster.com/#9464K35
This one, with the 25mm ID and 3.5mm thickness?
PostPosted: Fri Jul 24, 2020 1:22 pm    Post subject: Reply with quote
Yes, link is above as well.
Page 3 of 3
