931 S1 vacuum advance/retard..
PostPosted: Mon Jul 20, 2020 6:45 am    Post subject: 931 S1 vacuum advance/retard.. Reply with quote
The boost retard line is the one on the backside of the can right? Goes to the brake booster hose/manifold vacuum..
The one on the front goes to the ported vacuum on the TB right?
If so, then why does my idle change if I remove the line on the back of the can and plug it, while my idle does not change if I remove the line to the front of the can and plug it?
Confused..
I figured removing the boost retard line on the backside wouldn't change anything except for on boost, but this doesn't seem to be the case..
kondzi
PostPosted: Tue Aug 11, 2020 7:19 am    Post subject: Reply with quote
Not sure about 931/S1, but Iíve recently had a strong headache from 1986 930 US. This has two vacuum cans - one for boost retard, the other for vacuum advance control with additional idle advance when cold. The trick was there was US emissions system that advanced idle ignition a bit at cold engine by blocking vacuum to the idle can (letting in atmospheric air instead) When the engine warmed up, the solenoid valve opened and a fully functional vacuum advance was operational.
Maybe, but just maybe itís similar in 931/S1?
Konrad
'89 951 US
'81 931 RoW (TBD)
'74 Ford Capri 1.3 (factory specs)
