Has anyone done 2.0na high cr?
Goto page Previous  1, 2, 3
PostPosted: Sat Jun 27, 2020 12:42 am    Post subject: Reply with quote
I think it was Augidog who had a high CR NA made with S2 pistons + NA head.
Digging thru some of his old posts might be interesting:
http://www.924board.org/search.php?search_author=augidog
PostPosted: Sat Jun 27, 2020 12:48 am    Post subject: Reply with quote
safe wrote:
Note that you need "spacers" to center the rods on the crank with those bmw rods.
I'd be intereseted in how one would implement this solution.
safe
PostPosted: Sat Jun 27, 2020 1:00 am    Post subject: Reply with quote
Me too, probably making spacers on the small end centering in the piston.
gegge
PostPosted: Sat Jun 27, 2020 1:09 am    Post subject: Reply with quote
I made thick 22mm washers in aluminium in order to center the rod, nothing fancy. It is mportant that they are a tight fit to the wrist pin and doesn´t move. The inside of the piston was wedge shaped, two parallell surfaces to would be better thogh. But there are no horizontal forces on the rod so I guess it worked...
Carl Fredrik Torkildsen
TJC
PostPosted: Sat Jun 27, 2020 1:21 am    Post subject: Reply with quote
Many moons ago I did my time at a high performance/race engine machine shop in Phoenix, Az. I don't remember the application right off the top of my head, (probably a open wheel sprint car Chevy V8 or midget 4 cylinder engine), but we took rods that were too narrow at the big end and machined spacers from chrome moly tubing and then tack welded them onto the rods. we split them at the parting line of course, resized the rods and made sure they had the proper chamfer on them to facilitate proper clearance and oiling. I think we were using Carillo rods at the time. It was over 30 years ago and actually may have been for the all aluminum Chevy V4 engines we built for midgets...a designed first conceived by my late friend Ron Trainor.
'95 BMW 318i/5 ..."Pearl"
Still on the Prowl!
www.ttrs1.com
PostPosted: Sat Jun 27, 2020 1:24 am    Post subject: Reply with quote
Cool, thanks for that. Follow up questions:
1. So these washers are at the little end, placed over the pin bushing?
2. Rough estimate of the thickness of the washers?
3. Any thoughts on specific flavor of alu?
4. Why alu vs steel?
5. Any concerns about the alu deforming over time due to the harder metal of the rods and pin?
Page 3 of 3
