MOTANUL
Joined: 19 Nov 2018 Posts: 143 Location: ROMANIA BUCHAREST
Posted: Mon Jun 22, 2020 7:34 pm Post subject: Overhaul Porsche 931 S1 engine |
I plan to disassemble the engine in the fall to replace the following:
1-Piston rings
2-Piston pin
3-Connecting-rod bearing
4-Crankshaft bearing
-gaskets
If necessary, I will also replace the pistons.
The gaskets are already bought. The rest of the spare parts are more or less NLA.
exception: Connecting-rod bearing - rose pasion
Where to find the rest of the parts mentioned above? _________________ 1980 Porsche 924 Turbo (931) diamond silver metallic/helios blue metallic
sold Porsche 924 NA 1979 |
Joined: 08 Jan 2010 Posts: 2102 Location: Somerset, UK
Posted: Mon Jun 22, 2020 7:43 pm Post subject: |
1-Piston rings - Total Seal
2-Piston pin - why?
3-Connecting-rod bearing - Mittelmotor, 'colonel' on 924OC in UK
4-Crankshaft bearing - Mittelmotor, 'colonel' on 924OC in UK, there is a guy in France on here and 924OC remaking some
You will need to do rod bolts too. From Porsche or there was some ARP for sale on here. Similar price either way.
There is a thread on 924OC regarding forged pistons if required. But there are some cast OEMs now available from Porsche at circa €250 per piston. If you do pistons then the pin will be supplied _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
MOTANUL
Posted: Mon Jun 22, 2020 8:50 pm Post subject: |
1. Total Seal® Piston Rings Company Sold
This company? http://www.totalseal.com/
2-Piston pin - why? - If it is not necessary, I do not change it.
3-4 Mittelmotor
Pistons - Porsche If I am lucky
Thnak you for detail info. _________________ 1980 Porsche 924 Turbo (931) diamond silver metallic/helios blue metallic
Posted: Mon Jun 22, 2020 9:13 pm Post subject: |
If you change the pistons you should also machine/hone/match the cylinders.
Also, if you do this overhaul, dont forget about the head, new guides and valve stem seals, new springs, new tappets and obviously new valve seats, make sure you do a 3 angle job on the seats as i think whats on the car now is a 3 angle job, so if you change to new things make sure you match or improve the quality of whats on the car now, dont just assume new is better. _________________ SUPERCHARGED Ruby-sh 924 |
MOTANUL
Posted: Thu Nov 19, 2020 2:47 am Post subject: |
I took the 924 turbo engine compression: 8.2 8.4 8.6 8.2 bar
I did not find how much an ideal compression should be for 924 turbo engine.
At 924 NA I had found 12 bar.
I was unable to unscrew the exhaust manifold bolts. Some of them are rounded and blocked.  _________________ 1980 Porsche 924 Turbo (931) diamond silver metallic/helios blue metallic
MOTANUL
Posted: Mon Nov 30, 2020 9:53 pm Post subject: |
MOTANUL wrote: |
I noticed that several 924 turbo owners on the forum made a major engine repair. Did no one measure the compression after the repair? I am very curious how many (bar/PCI) got on average on each cylinder after the repair.
I disassembled the engine. The cylinder head is removed. The strangest thing discovered would be the upper segments (compression) made of 2 pieces. All 4 are composed of 2 pieces 1/3 + 2/3.
Piston size 86,75 mm (Mahle)
The exhaust gallery has a rather long crack.
The piston shirts look pretty good.
I will measure in the near future:
Cylinder block, Pistons, Connecting rod bush, Crankshaft bearings
Joined: 29 Jul 2001 Posts: 8373 Location: Royal Oak, MI, USA
Posted: Mon Nov 30, 2020 11:06 pm Post subject: |
Sadly, though I did rebuild, i didn't get the rings broken in properly, my fault/problem, so I don't have any usable compression numbers.
Will be fixing that this spring.
Note that the compression in a Turbo should be lower than an NA due to a lower CR. _________________ Vaughan Scott
'79 924 #77 ITB racecar
Posted: Tue Dec 01, 2020 12:00 am Post subject: |
Its not good practice to use others compression test results as an absolute number. Too many variables...... CR ratio, uncalibrated gauges, differing temperatures.... etc. And to be honest, I never checked in the 6yrs since rebuild _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Cédric
The cracked top rings is something ive seen on several s1 engines, including the one my original engine. Ive not encountered the same on the s2 engines, so some changes might have been made in production.
Regarding compression, i think my s2 engine was around 10,5 something bar. But it was made along time ago so i cant remember it in detail. _________________ 1980 924 Turbo |
MOTANUL
Posted: Tue Dec 01, 2020 1:23 am Post subject: |
C�dric wrote: | The cracked top rings is something ive seen on several s1 engines, including the one my original engine. Ive not encountered the same on the s2 engines, so some changes might have been made in production.
Regarding compression, i think my s2 engine was around 10,5 something bar. But it was made along time ago so i cant remember it in detail. |
I thought I was the only one in the world who discovered something like that. No friend of mine ever encountered craked top rings in other engines (of course not Porsche 931- other brands / model).
I expect S1 to have less than 10.5 bar.
The Porsche 924 turbo (931) is a total lack of information. In golf 2 for example there is a program in which you enter:
- engine code
- thickness of the head gasket
- Piston protrusion
- Inner diameter of head gasket
- Capacity of piston (cm3)
- Capacity of head (cm3)
- CAPACITY OF COMBUSTION CAMBER (Stroke: / Bore:)
And you receive results. _________________ 1980 Porsche 924 Turbo (931) diamond silver metallic/helios blue metallic
Posted: Tue Dec 01, 2020 7:39 am Post subject: |
MOTANUL wrote: | C�dric wrote: | The cracked top rings is something ive seen on several s1 engines, including the one my original engine. Ive not encountered the same on the s2 engines, so some changes might have been made in production.
- engine code
- Piston protrusion
And you receive results. |
We used to have that supplied by Ideola's Garage. It calculates the compression ratio. Unfortunately its gone unless someone can host it instead of Dan? _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
jacobroufa
Joined: 18 Nov 2016 Posts: 309 Location: Rockford, IL
MOTANUL
Posted: Wed Dec 02, 2020 5:42 am Post subject: |
Thank you @jacobroufa
I studied the pistons and segments a bit yesterday. From what I managed to understand, the S2 pistons are different from the S1 ones. But the segments seem to have the same dimensions.
Is it a good idea to use S2 segments instead of S1?
S2 Withstands better compression ratio, higher power, etc. _________________ 1980 Porsche 924 Turbo (931) diamond silver metallic/helios blue metallic
Posted: Wed Dec 02, 2020 7:41 am Post subject: |
MOTANUL wrote: | Thank you @jacobroufa
S2 Withstands better compression ratio, higher power, etc. |
S1 = offset bowl ~45cc & 7.5:1 CR (+ any skim of head)
S2 = central bowl ~35cc & 8.5:1CR (+ any skim of head)
S2 piston would be my preferred design, but with a slightly thicker Cometic MLS headgasket to bring CR below 8.5:1 for sub 1bar boost. Closer to 8 - 8.2:1CR if wanting over 1bar boost. Big boost would need to be closer to 7.5:1 _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
MikeDanger
Posted: Wed Dec 02, 2020 5:57 pm Post subject: |
are you sure s2 is 8.5:1?? thought it was 8.0
944 turbo is 8.5 _________________ It was either this or a giant box of legos |
