Juho
Posted: Fri Nov 08, 2019 7:04 am Post subject: |
safe wrote: | Just make one. Cardboard template, some aluminium sheet and an electric jigsaw. |
I got other stuff from them so i bought the backplate aswell |
Juho
Posted: Fri May 15, 2020 11:35 pm Post subject: |
Tried to fire her up today but carburetors were flooding. Any idea why? tried to loosen the fuel preassure regulator and blocking second fuel return lines, theres two in carbs and one in fuel preassure regulator
https://youtu.be/RFWaPxsQ5y0 |
safe
Posted: Fri May 15, 2020 11:45 pm Post subject: |
How much fuel pressure? |
Juho
Posted: Sat May 16, 2020 1:19 am Post subject: |
probaly 2 psi, loosened it all the way |
safe
Posted: Sat May 16, 2020 1:30 am Post subject: |
Have you adjusted the float bowl level?
Disclamer: Carbs are not my forte. |
Juho
Posted: Sat May 16, 2020 3:49 am Post subject: |
not yet, didnt have time to take them off because had to leave to work |
Juho
Posted: Mon May 18, 2020 1:24 am Post subject: |
ok the two tubes on the top arent returns... they are just breathers |
safe
Posted: Mon May 18, 2020 1:44 am Post subject: |
Carbs Usually doesnt have returns. The floats just closes the "fill valve" needle valve. So to set the floats levels is crusial. |
Posted: Mon May 18, 2020 2:55 am Post subject: |
Safe's right. On my Webers I run a fuel pressure regulator at 2psi(max for Webers is maybe 3.5. with no return. In US Holley 804 is an inexpensive fuel pressure regulator. I also use a Carter P4070 fuel pump something like 4-8 psi output.. Many of the racers use Facet pumps, but not the really cheap cube one. Different carbs will want different fuel pressures. Some pressure regulators will have a bypass/return in them.
On the race car I have an in line pre filter (85-100m) Then run thru the pump to a stock 924 Bosch filter(interesting finding fittings) then the pressure regulator. The street car just has a really cheap($3) plastic filter from any flaps. _________________ Mike
'67 MG Midget Dp
Juho
Posted: Mon May 18, 2020 4:50 am Post subject: |
gonna take them off tomorrow and clean the needles and if that doesent fix it ill try to set the float level no idea how to do it though |
Juho
Posted: Thu May 21, 2020 4:02 am Post subject: |
https://www.youtube.com/watch?v=Pt-77UrGv0M
should they be like this when i flip them upside down and back they sometimes they get stuck. they go back by pushing or hitting bowl with screw driver. |
Juho
Posted: Sat May 23, 2020 6:06 am Post subject: |
Cleaned carbs today and the they still flood |
safe
Posted: Sat May 23, 2020 6:24 am Post subject: |
What kind of carb is it!?
The 40ish degree you have mounted the carbs at, is that within the allowed spec?
As Ive said, Im no carb Guru, but i think you must mount them pretty much horisontal. |
Juho
Posted: Sat May 23, 2020 7:45 am Post subject: |
ive seen plenty mounted at an angle like this. i think i need to adjust level but no idea how to do it. |
Juho
Posted: Sun May 24, 2020 6:03 am Post subject: |
Another day of testing, mounted the carburetors more horizontally. Tried to bending the tangs that adjust the float level from all they way up to all way down. Any of those didn't help and the carburetors are still flooding.
