1980 Porsche 924 turbo aesthetic restoration mainly
Goto page Previous  1, 2, 3
PostPosted: Thu Jan 03, 2019 7:04 pm    Post subject: Reply with quote
The images above for the clutch and pressure plate appear to be showing a rubber damped clutch and deep pressure plate. This is a series 2 set up. The series 1 set up for a spring damped clutch, the S1 pressure plate is now nla and replaced by the 911/915 plate. Make sure you buy the right components or make sure they are interchangeable with S1 and S2 set ups. Your car should be S1 spec, but a few things on it are S2 spec - oil breather, turbo. So don't assume until double checking that the motor hasn't been swapped out in the past.
(S1 and S2 have different flywheels, clutch, pressure plates)
PostPosted: Thu Jan 03, 2019 10:01 pm    Post subject: Reply with quote
The clutch is a spring clutch on that car, woolie changed the clutch when the car was still in UK. Engine is the original S1.
MOTANUL
PostPosted: Tue Jan 08, 2019 1:09 am    Post subject: Reply with quote
This WE.
I will leave the current topic only for pictures and non-technical discussions.
I will post the "to do list" in the area "931 Tech."
1980 Porsche 924 Turbo (931) diamond silver metallic/helios blue metallic
sold Porsche 924 NA 1979
MOTANUL
PostPosted: Mon May 20, 2019 6:12 am    Post subject: Reply with quote
Pics
PostPosted: Mon May 20, 2019 5:44 pm    Post subject: Reply with quote
Great to see that car doing well.
MOTANUL
PostPosted: Mon Jun 17, 2019 3:40 am    Post subject: Reply with quote
I participated in the regularity Rally of Moldavia - 1000 km in 3 days. The car did not have any major problems. Only AC did not work.
MOTANUL
PostPosted: Sun Mar 29, 2020 3:57 am    Post subject: Reply with quote
Before and after covid.
TJC
PostPosted: Mon Mar 30, 2020 12:06 am    Post subject: Reply with quote
'95 BMW 318i/5 ..."Pearl"
Still on the Prowl!
www.ttrs1.com
MOTANUL
PostPosted: Fri Apr 03, 2020 4:24 am    Post subject: Reply with quote
The hood and the interior is ready.
PostPosted: Fri Apr 03, 2020 5:15 am    Post subject: Reply with quote
This has transformed from a ratty cool 931 into a near perfect 931.
Great job !
Page 3 of 3
