1979 924 Daily driven project
Goto page Previous  1, 2, 3
DZGunner
PostPosted: Wed Apr 01, 2020 6:59 am    Post subject: Reply with quote
Do they also carry the seal as well?
1980 931 S (The project)
1979 924 (Daily driver)
1979 924 (Parts)
1977 924 (Pop's)
1977 924 (Parts)
DZGunner
PostPosted: Sat Apr 04, 2020 1:25 pm    Post subject: Reply with quote
Finally got some mail in today, allowing me to move forward a bit. New pilot bearing insert/seal/bearing, RMS, oil pan gaskets, clutch kit, hardware. The pilot bearing going in was easier than I was anticipating. Just threaded the same bolt I used to extract it into the back of it and tapped it with a hammer until it was fully seated. EZ PZ
1979 924 (Parts)
1977 924 (Pop's)
1977 924 (Parts)
DZGunner
PostPosted: Sun May 17, 2020 11:38 am    Post subject: Reply with quote
I haven't posted in a while, but It's because I've been doing a lot of hacking, online shopping, and measuring to see how I can make things work. Today I finally got to throw things together to vaguely get an idea of how everything might fit. Essentially I'm just missing the EFI kit at this point, so there's no fuel rail/FPR/injectors or harness, but when measuring everything I made sure to leave room for the other components as best as I could. This is what I've come up with so far.
The Idle air control valve Is from my old and sold 87 928 S4. Obviously the hose coming from the IACV that appears to be too long Isn't actually cut to size yet, but simply illustrating where It's intended to be routed to. The Audi TB actually had a piece on the side that was perfect to route to the IAC valve, but it was protruding in such a way that it interfered with the 180 degree intake pipe. So I had to hack it up and put a brass 90 degree elbow in its place. I gotta say, It's all fitting like a glove... for now...
1979 924 (Parts)
1977 924 (Pop's)
1977 924 (Parts)
Page 3 of 3
