Forged engine
Juho
PostPosted: Sat Mar 28, 2020 6:24 am    Post subject: Forged engine Reply with quote
My 924 (hopefully) driving soon, i want to get a new project, a 2.0 liter na to build over the summer while driving the 924 and drop it in over the winter.
Ive bought efi and supercharger for the engine, and im still looking for the engine
My current plan is to get the aliexpress rods. idk if they are any good. and some forged vw flat tops.
Would the POR-144 rods fit? No inventory sadly.
https://www.aliexpress.com/item/32895252693.html?spm=a2g0o.productlist.0.0.401ec940VKQh2b&algo_pvid=90c4683b-8dde-48e2-89d7-ff0d07e62c16&algo_expid=90c4683b-8dde-48e2-89d7-ff0d07e62c16-12&btsid=0ab6fb8815853392429882231edb5f&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
Would a thick cometic headgasket be enough to lower the compression for the sc? My goals are just 1 bar of boost and 7k rpm. And yes im going with na head.
Any advice would be greatly appreciated since im a noob when it comes to assembling engine with aftermarket parts.
gegge
PostPosted: Sat Mar 28, 2020 8:46 pm    Post subject: Reply with quote
I belive "safe" bought a set of these rods. I am interested, but had my mind on another project...
Carl Fredrik Torkildsen
CÚdric
PostPosted: Sat Mar 28, 2020 10:22 pm    Post subject: Reply with quote
That's a very ambitious bottom en for 1 bar of boost
┤80 924 Turbo
Juho
PostPosted: Sun Mar 29, 2020 8:28 am    Post subject: Reply with quote
https://www.aliexpress.com/item/32782381728.html
He bought this set i think, the shipping is stupid expensive, 150 dollars to finland :/
Juho
PostPosted: Sun Mar 29, 2020 8:30 am    Post subject: Reply with quote
Doing it for the sake of learning, and maybe ill change the supercharger in to turbo at some point
safe
PostPosted: Sun Mar 29, 2020 7:28 pm    Post subject: Reply with quote
I have the por-046.
A lot cheaper when I bought them and shipping basicly free.
joewest
PostPosted: Tue Mar 31, 2020 1:28 am    Post subject: Reply with quote
I doing a somewhat similar build now. Here are a few images:
https://photos.app.goo.gl/Mua2zeV8zLs5DUgE9
'79 924 Track Prepared (currently under supercharger upgrade)https://photos.app.goo.gl/Mua2zeV8zLs5DUgE9
'80 931 Daily Driver
"The number of posts in my profile may represent the number of times I have screwed something up...and admitted it here."
PostPosted: Tue Mar 31, 2020 4:05 pm    Post subject: Reply with quote
Oh Joe! What lovely workmanship you've got going on there.........a real credit to you.
joewest
PostPosted: Tue Mar 31, 2020 11:28 pm    Post subject: Reply with quote
Thanks! I am VERY ready to finally get it running and back out on the track.
jazz guy
PostPosted: Wed Apr 01, 2020 2:49 am    Post subject: Reply with quote
Great work, Joe! Wow! Looking forward to seeing updates once it's up and running.
'81/'81/'82
Raize
PostPosted: Wed Apr 01, 2020 7:19 pm    Post subject: Reply with quote
Reminds me of mine that will never be finished because something always comes up and stops me from working on it. Hopefully you'll not end up in the same trap.
1981 N/A daily driver.
Modifications: Headlight relays. Vacuum gauge. Cold start switch. Kill switch. Ported cylinder head, intake and exhaust. Brake booster venturi delete. 53/35mm throttle body. M62 supercharger mounted but not connected
Juho
PostPosted: Tue Apr 07, 2020 3:00 am    Post subject: Reply with quote
what off the shelf pistons would you go in a build like this?
PostPosted: Tue Apr 07, 2020 6:19 pm    Post subject: Reply with quote
May be still available? https://porsche924.co.uk/forum/viewtopic.php?f=12&t=33549
Juho
PostPosted: Wed Apr 08, 2020 1:28 am    Post subject: Reply with quote
Would off the shelf piston be better and cheaper? How strong are these and can i run with na block and head?
PostPosted: Wed Apr 08, 2020 3:54 am    Post subject: Reply with quote
They are NA spec forged pistons made by Omega, well known UK manufacturer of strong pistons, find anything else 'on the shelf' stronger!? Doubt you'll find a brand new set of NA specific pistons any cheaper either. Richard who is selling is a top guy and probably post to Finland.
No idea of other options, I'm not NA specialist.
