Fuel pump issue, no power to pump
Goto page Previous  1, 2
winddude
PostPosted: Fri Mar 27, 2020 4:48 am    Post subject: Reply with quote
After testing a new relay, still nothing. All the voltage check out at the relay, except possible terminal 1 or L12 on the relay board, connects to coil. I'm only getting 2v. What is the voltage from the coil supposed to be?
PostPosted: Fri Mar 27, 2020 6:33 am    Post subject: Reply with quote
That coil connection tells the relay that the engine is turning over. That means the relay does not close until the car is cranking and making spark.
winddude
PostPosted: Fri Mar 27, 2020 12:16 pm    Post subject: Reply with quote
I'm getting 2v when cranking. Maybe that's not enough voltage to close the relay, due to a bad coil, or the new relay is bad. Spark seems strong. Any idea how how many volts should be coming through L12 or 1 on the relay board? The haynes manual says test for voltage between L12 and L15, but not what to expect.
winddude
PostPosted: Mon Mar 30, 2020 8:42 am    Post subject: Reply with quote
BUMP
anyone know the voltage that shoudl be coming off of terminal 1 on the coil?
Page 2 of 2
