S1 Timing Troubles
poor-sche
PostPosted: Thu Mar 26, 2020 10:17 am    Post subject: S1 Timing Troubles Reply with quote
I think I screwed up. I removed the timing belt in order to replace the water pump; 2 times. The first time the car started without issue, but the replacement pump leaked. The second time the pump was water tight but the car won't start.
Just checked timing marks and my camshaft mark (dot) is 180 off from the flywheel mark (z1). The crank I rotate by hand easily, the cam only rotates about 30 with a wrench.
How do I get it back into time? Did I bend my valves?
PostPosted: Thu Mar 26, 2020 12:19 pm    Post subject: Reply with quote
Most likely you have bent valves, but to make sure:
Remove spark plugs
Turn crank 90 degrees from TDC (this places all pistons half way down their bores)
Turn cam to its mark
Turn crank back to TDC
Install belt
Check distributor for rotor cylinder 1 alignment.
Do a compression test.
If compression is good, install plugs, start car, adjust ignition timing.
poor-sche
PostPosted: Thu Mar 26, 2020 2:39 pm    Post subject: Reply with quote
Thanks Paul!
Got it back in time and ran compression. All 4 cylinders consistently read 118 to 120 psi. That can't be right, can it? Put it back together and it fired right up. No weird noises no hesitations. It is idling too high however, 2,000 rpm. I'll put my timing light on it tomorrow to adjust.
PostPosted: Fri Mar 27, 2020 12:45 am    Post subject: Reply with quote
Glad to help! The fact that these engines have a 7.6 compression ratio and variances in gauges and testing methods might explain your readings. I wouldn't worry since all cylinders are reading much the same.
