Indicator and hazard problems
felix83
PostPosted: Fri Mar 20, 2020 5:08 pm    Post subject: Indicator and hazard problems Reply with quote
My indicators don't work, nothing happens when flicking the switch. If i turn them on with everything off, the parking lights come on on the corresponding side, as they should. I've cleaned up the stalk assembly itself, the fuse holders (replacing all fuses for good measure) and the grounding points under the dash.
My hazards do work, however they seem to have developed an intermittent arrythmia:
https://www.youtube.com/watch?v=J1qGk7IsCb4
Could this be indicative of the flasher relay starting to go bad?
The thing is, after cleaning the stalk switch and the fuse box, the indicators worked fine. The problem appeared after cleaning the grounding points and fixing a broken connector on one of the cables.
Felix
'77 924
'82 911 SC
Instagram: @orebro.classics | @924.resurrection
K-Roll931
PostPosted: Sat Mar 21, 2020 4:52 am    Post subject: Reply with quote
That's odd, my car has the opposite issue: Indicators work, and the hazards don't. They haven't worked in at least a year.
'80 931 M471 - Dolomite Gray -> Monaco Blue
felix83
PostPosted: Sat Mar 21, 2020 5:55 am    Post subject: Reply with quote
Ah, the joy of old cars. Have you checked the hazard switch?
Felix
'77 924
'82 911 SC
K-Roll931
PostPosted: Sat Mar 21, 2020 11:16 am    Post subject: Reply with quote
I replaced it, and the fuse. I might've changed the relay or flasher (whichever its called), can't remember... There was no change regardless.
felix83
PostPosted: Sun Mar 22, 2020 9:26 am    Post subject: Reply with quote
In my case, it was the stalk itself. Despite my attempts to clean it, it still ha a bad connection. I've dismantled it and will try fixing it before ordering a new one.
Felix
'77 924
'82 911 SC
K-Roll931
PostPosted: Sun Mar 22, 2020 11:06 am    Post subject: Reply with quote
I forgot about that! I changed that too with no change other than a clean and shiny stalk. I'll have to replace that flasher/relay and report back on that sometime.
felix83
PostPosted: Sun Mar 22, 2020 6:15 pm    Post subject: Reply with quote
Since the hazards and indicators use the same flasher, I don't think a bad relay should cause one to stop working and not the other. I'd inspect the hazard switch socket for damage, which could explain your issue. The hazard switch is the big thing marked with E3.
Felix
'77 924
'82 911 SC
