Will a 968 brake booster fit in the 924?
PostPosted: Fri Feb 28, 2020 4:18 pm    Post subject: Will a 968 brake booster fit in the 924? Reply with quote
937 DITC
PostPosted: Sat Feb 29, 2020 12:17 am    Post subject: Reply with quote
Don't know about the 968, but I have the 944 9" booster in the track car. It bolts right up, but I had to relocate the throttle cable hole in the firewall for clearance. Using the 944 top hat, it is also longer meaning the brake lines no longer fit and tilts up at a slight angle which is not a problem with hood clearance.
You might look at changing the hole location in the brake pedal to increase the pedal ratio as the Chevy LS conversion folks have done. I think the 7" booster is a 2-1 ratio and the 9" is a 3-1. Might well be wrong on that.
Mike
'77 924
cricketdesigns.com
Raize
PostPosted: Sat Feb 29, 2020 6:05 am    Post subject: Reply with quote
I read it will hit the CIS.
1981 N/A daily driver.
Modifications: Headlight relays. Vacuum gauge. Cold start switch. Kill switch. Ported cylinder head, intake and exhaust. Brake booster venturi delete. 53/35mm throttle body. M62 supercharger mounted but not connected
