Crankshaft pulleys
Raize
PostPosted: Tue Feb 18, 2020 9:07 am    Post subject: Crankshaft pulleys Reply with quote
This is a pulley with a trigger wheel mod and two v-belts (one for A/C?).
https://lh3.googleusercontent.com/-9e2-0JXJ6VQ/T5Mu0N9bPnI/AAAAAAAAWBo/s0aoS7KvYgY/s800/IMG_2005.JPG
This seems to be another, simpler type of pulley with one v-belt.
https://cdn.rosepassion.com/048105255a-p5540-v-belt-pulley-single-groove-photo-5540-0-048105255A.jpg?w=1920&h=1080&format=jpg-95
It seems to me that these pulleys would not have the same alignment on the first V-belt.
Ignoring RHD cars, which of these is the normal pulley?
1981 N/A daily driver.
Modifications: Headlight relays. Vacuum gauge. Cold start switch. Kill switch. Ported cylinder head, intake and exhaust. Brake booster venturi delete. 53/35mm throttle body. M62 supercharger mounted but not connected
Raceboy
PostPosted: Wed Feb 19, 2020 5:28 pm    Post subject: Reply with quote
Regular one is with one v-belt pulley.
First photo you posted is for 931, allows the alternator to be fitted on the left side of the engine and then belt would be more outside requiring flipping water pump pulley too.
Same pulley is used with 931's that have A/C.
AC equipped n/a ones have pulley with two v-belt pulleys, one for alternator and one for A/C compressor.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
Raize
PostPosted: Sat Feb 22, 2020 9:03 pm    Post subject: Reply with quote
Thanks, makes sense.
