Wiring diagram for DITC 931 ROW
PostPosted: Sat Feb 01, 2020 5:22 pm    Post subject: Wiring diagram for DITC 931 ROW Reply with quote
I am looking for a wiring diagram from the DITC for the 931 ROW version, I can only seem to find the USA version.
937 DITC
PostPosted: Sat Feb 01, 2020 5:33 pm    Post subject: Reply with quote
If you undid the connector and dont know the wire color to pin corelation i think i have a picture to help.
But not a diagram.
Ruby-sh 924
PostPosted: Sun Feb 02, 2020 2:05 am    Post subject: Reply with quote
Morghen, thank you, but I a looking for the full wiring diagram
937 DITC
PostPosted: Sat Feb 08, 2020 6:58 am    Post subject: Reply with quote
Nobody?
937 DITC
PostPosted: Sat Feb 08, 2020 7:01 am    Post subject: Reply with quote
You mean the square connector like where those wires go, right?
I remember finding that on google a few years ago.
Ruby-sh 924
PostPosted: Sat Feb 08, 2020 5:48 pm    Post subject: Reply with quote
Found one, it says USA but doesn't have the idle stabilazor, so I thnik it is the same as ROW.
https://farm3.static.flickr.com/2193/2399050926_b6825efef7_o.jpg
937 DITC
PostPosted: Sat Feb 08, 2020 6:50 pm    Post subject: Reply with quote
I still have some issues with cutting of at higher rev, I think it might be bad ground or 12V+ to the DITC so want to check the wires/ connectors/ ground.
For ground, I need to check:
Ground no 13, where can I find this ?
Connector T9a in engine compartment
For 12V+, I need to check:
C15 on the fuse box
Green wire no1 from fuel relay
Black/blue wire from fuse box a12
937 DITC
