Posted: Sat Feb 01, 2020 5:22 pm Post subject: Wiring diagram for DITC 931 ROW |
I am looking for a wiring diagram from the DITC for the 931 ROW version, I can only seem to find the USA version. _________________ 937 trackday car
Posted: Sat Feb 01, 2020 5:33 pm Post subject: |
If you undid the connector and dont know the wire color to pin corelation i think i have a picture to help.
But not a diagram. _________________ https://www.the924.com |
Posted: Sun Feb 02, 2020 2:05 am Post subject: |
Morghen, thank you, but I a looking for the full wiring diagram _________________ 937 trackday car
Posted: Sat Feb 08, 2020 6:58 am Post subject: |
Nobody? _________________ 937 trackday car
Posted: Sat Feb 08, 2020 7:01 am Post subject: |
You mean the square connector like where those wires go, right?
I remember finding that on google a few years ago. _________________ https://www.the924.com |
Posted: Sat Feb 08, 2020 5:48 pm Post subject: |
Found one, it says USA but doesn't have the idle stabilazor, so I thnik it is the same as ROW.
https://farm3.static.flickr.com/2193/2399050926_b6825efef7_o.jpg
Last edited by Dutch924-racer on Sat Feb 08, 2020 6:50 pm; edited 1 time in total |
Posted: Sat Feb 08, 2020 6:50 pm Post subject: |
I still have some issues with cutting of at higher rev, I think it might be bad ground or 12V+ to the DITC so want to check the wires/ connectors/ ground.
For ground, I need to check:
Ground no 13, where can I find this ?
Connector T9a in engine compartment
For 12V+, I need to check:
C15 on the fuse box
Green wire no1 from fuel relay
Black/blue wire from fuse box a12 _________________ 937 trackday car
