Where to get OEM hose elbows and connectors
mattaebersold
PostPosted: Fri Jan 24, 2020 6:15 am    Post subject: Where to get OEM hose elbows and connectors Reply with quote
I'm embarking on a top-end rebuild for my 931, and I'm curious if there's a definitive list of all of the elbows and hose connectors. I would prefer OEM Porsche, or ideally silicone aftermarket ones, but I'm unsure of where to go and what to get.
I got this kit for all the vacuum lines:
http://www.hiperformancestore.com/porsche.htm#924
what I got (as expected) was some reams of hose in various diameters, which will be great for the lines, but there's none of the larger elbows and connecting pieces.
Does anyone have a resource or a list that I can order from?
2005 Touareg V8
2006 530xi Wagon
PostPosted: Fri Jan 24, 2020 7:22 am    Post subject: Reply with quote
I've gotten 1/2" silicon hose elbows to replace a number of the elbows on my car. Source you can probably get from Summit or JEGS... very generic stuff...
'79 924 #77 ITB racecar
PostPosted: Fri Jan 24, 2020 9:15 am    Post subject: Reply with quote
PET will give you part numbers and sizes. Most are still available from Porsche dealers. Some will need you to be creative as they are NLA
poor-sche
PostPosted: Fri Jan 24, 2020 12:47 pm    Post subject: Reply with quote
Read ideola’s post in this thread for required sizes...
http://www.924board.org/viewtopic.php?t=42292&sid=537303e5f2f14f2e89ec14cdde3d051c
mattaebersold
PostPosted: Sat Jan 25, 2020 3:30 am    Post subject: Reply with quote
That's exactly what I was after! Thank you!
2005 Touareg V8
2006 530xi Wagon
mattaebersold
PostPosted: Sat Jan 25, 2020 3:44 am    Post subject: Reply with quote
So looking for a place to get these:
I see pelican has the 18mm elbows, which I would need 4 of them:
https://www.pelicanparts.com/More_Info/93111018301OEM.htm?pn=931-110-183-01-OEM&bt=Y&fs=0&SVSVSI=986
But I'm unsure of where to source the other parts (the 14mm elbows). I get that the straight connectors I can just cut from a line, but those 14mm elbows I would prefer to buy new'
https://www.lindseyracing.com/LR/Porsche/LR-AOS-101.html
These ones were discussed in the thread, but the site doesn't list the mm diameter?
2005 Touareg V8
2006 530xi Wagon
PostPosted: Sat Jan 25, 2020 5:58 am    Post subject: Reply with quote
Porsche dealer
Porsche will not remake NLA or soon to be NLA stock unless they see retail demand for certain models and their parts
