Brake Fluid Change?
PostPosted: Fri Jan 10, 2020 12:04 am    Post subject: Brake Fluid Change? Reply with quote
I have Motul RBF600 in the race car brake system, do I need to change it out completely over the winter or will just a thorough bleeding suffice? I'm also de-glazing the pads between race weekends.
Mike
'77 924
cricketdesigns.com
CÚdric
PostPosted: Fri Jan 10, 2020 12:15 am    Post subject: Reply with quote
For your kind of use I would do it (I did when i tracked reaguarly) every winter. If you do it correctly it just about works with a 0,5l can of RBF600 to get all the old fluid out, so its not very expensive.
Thanks to some US law of stupidity you cant buy ATE racing blue any more. Otherwise altering between the blue fluid and RBF600 was a brilliant way of knowing when the old fluid was flushed out. But at least I learnt that 0,5l is enough to completely change the fluid
┤80 924 Turbo
PostPosted: Fri Jan 10, 2020 5:03 am    Post subject: Reply with quote
I do a complete flush of the 600 every year. For a few years, I added a tiny bit of food coloring to the clear new fluid to be able to tell when the old fluid was gone and then the next year just use the clear until the colored fluid was gone. Maybe that's why when I hit the brakes I smell cupcakes
1979 924 NA race car
1982 924 Turbo almost a PoS
PostPosted: Fri Jan 10, 2020 12:13 pm    Post subject: Reply with quote
OK, will do
Mike
'77 924
cricketdesigns.com
PostPosted: Fri Jan 10, 2020 11:48 pm    Post subject: Reply with quote
I flush every year, regardless of usage.
'79 924 #77 ITB racecar
Post new topic   Reply to topic    924Board.org Forum Index -> 924 Racing Today All times are GMT + 11 Hours
