1980 924 power booster (all disc brakes 5 lugs)
Dltfam51
PostPosted: Sun Jan 05, 2020 6:14 am    Post subject: 1980 924 power booster (all disc brakes 5 lugs) Reply with quote
My power booster needs replacement cant seam to find one . I was wondering if this car used a 944 booster.
1980 924 all disc brakes 5 lug wheels.
PostPosted: Sun Jan 05, 2020 9:10 am    Post subject: Reply with quote
Measure your booster diameter. The 944 is a 9" dia, many of the 924 are 7". The 944 booster assembly is longer also(with the fire wall spacer) protrudes from the firewall further. I have a 9" in the track car and had to relocate the throttle cable due to interference with the larger booster.
Mike
'77 924
cricketdesigns.com
Brockoli
PostPosted: Tue Jan 07, 2020 7:28 am    Post subject: Reply with quote
I just replaced mine last year or the year before that. It was difficult to find. I eventually bought one from Rockauto that was a remanufactured unit. It works nicely however when they reassembled the booster they slightly rotated the two halves from the proper orientation. My master cylinder sits at a slight angle now.
