Salox CIS rebuild kit HOW MUCH LOCTITE?!
vdub6v
PostPosted: Fri Jan 03, 2020 7:30 am    Post subject: Salox CIS rebuild kit HOW MUCH LOCTITE?! Reply with quote
http://salvox.com/info.php?articles&articles_id=7
I'm going to use one of these kits and can't find a good indication of how much loctitie 542 to use on the cast iron distributor halves. Obviously don't want to create a clog. Do I smear it just around the outer edge or do I run it between each cavity?
Volkswagens!!!!
PostPosted: Fri Jan 03, 2020 8:20 am    Post subject: Reply with quote
I put it sparingly on both halves and scrape it with a razor blade so that it's very thin on both halves. Keep it out of the holes.
1979 924 NA race car
1982 924 Turbo almost a PoS
