The Green 931 -my first transaxle ever (resurrection thread)
Goto page Previous  1, 2, 3, 4, 5, 6
BTRacing
PostPosted: Thu Dec 05, 2019 1:54 pm    Post subject: Reply with quote
Why not to use early offset 944 Turbo knuckle, rotor and caliper ?
I am using late offset front and rear 944 Turbo parts for my GTR build Car is wide body so late offset actually helps with correct wheel spacing.
I like 944 T calipers for easy race pad selection. I know that it is same with Boxster calipers but off the shelf parts are just easier to get ad bolt on directly.
www.btr-chicago.com
1977 924 Mars Red all original-FOR SALE !
1977 924 Martini
2017 GMC Canyon Denali daily driver
kondzi
PostPosted: Thu Dec 05, 2019 8:44 pm    Post subject: Reply with quote
It's much easier to find Boxster calliper honestly. At least here.
Konrad
'89 951 US
'81 931 RoW (TBD)
PostPosted: Fri Dec 06, 2019 7:21 am    Post subject: Reply with quote
kondzi wrote:
And I need to upgrade the master cylinder obviously. The 944 one should be fine.
931 944 951 masters are all the same other than their failsafe mechanisms, no change in displacement or bias between them..
https://rennlist.com/forums/944-turbo-and-turbo-s-forum/886294-rear-calipers.html
kondzi
PostPosted: Fri Dec 06, 2019 7:39 am    Post subject: Reply with quote
Good stuff, thanks. Did you keep the X setup, or changed for fronts/rears?
Konrad
'89 951 US
'81 931 RoW (TBD)
PostPosted: Fri Dec 06, 2019 8:32 am    Post subject: Reply with quote
Still X but plan to change..
Trick brakes fell down the priority list..
kondzi
PostPosted: Sun Dec 29, 2019 8:14 am    Post subject: Reply with quote
Managed to find 951 rear callipers. Less expensive than Boxter + Brackets, but need to do a full rebuild on them.
Konrad
'89 951 US
'81 931 RoW (TBD)
MOTANUL
PostPosted: Mon Dec 30, 2019 1:01 am    Post subject: Reply with quote
944 S2 have diferent master and also ABS system.
I wanted to put on my car but the system was too different and involved too many modifications and adaptations.
Nice looking rear callipers
sold Porsche 924 NA 1979
PostPosted: Mon Dec 30, 2019 9:36 pm    Post subject: Reply with quote
I use 968 (same as 944T/944S2) front and rear calipers on stock 931 piping/master and boost system. No issues....great brakes, and this is a track car.
Rear calipers bolt straight on over existing disc. Front calipers were slightly modified to suit bolt pattern, over 911 C2 discs, longer studs and 6mm spacer.
It's been on the car for over 20 years.
kondzi
PostPosted: Tue Dec 31, 2019 10:26 pm    Post subject: Reply with quote
My setup will be 996 Turbo front callipers and rotors, 944 Turbo rear callipers and early 944 Turbo rear rotors. I plan to change the master cylinder from 23.8 to 25.4 as fitted in the 911 RS. It's damn cold during winter, so probably more progress in few months
Konrad
'89 951 US
'81 931 RoW (TBD)
Page 6 of 6
