Golten951
Posted: Fri Jan 04, 2019 4:33 am Post subject: |
morghen wrote: | cool ! get it started already |
Haha I wish I could!! Going to be great! |
ras924
Joined: 20 Dec 2011 Posts: 20 Location: Columbia Heights, MN
Posted: Sun Feb 03, 2019 4:21 am Post subject: |
...nice to see you are still moving forward!!! _________________ 1980 924 N/A - White
1978 924 N/A - Yellow Rally Car |
Golten951
Posted: Tue Feb 26, 2019 4:06 pm Post subject: |
Thanks Ras924, doing my best with alotted time and all.
I will be taking a week off to get more progress next month! ras924 wrote: | ...nice to see you are still moving forward!!! |
Golten951
Golten951
Posted: Thu Aug 29, 2019 9:55 am Post subject: Update |
I am breaking away from all stock gauges for my Audi 4.2L Swap in my 924. Main reason is I would like to try and make this car Legal in CA to actually drive around. So I am going to use an A8 cluster and, match everything up with the harness. also will have the OBD2 port set up, so I can read any codes and trouble shoot as much as possible. At first I wanted to stay stock gauges, but in the end, this will be very accurate. |
Golten951
Golten951
Posted: Wed Sep 04, 2019 2:21 pm Post subject: Update |
Modification of Harness from the 2001 A8 donor car underway, trimming it down to what is needed for my 924 Audi 4.2 Swap. leaves me with a lot of extra wiring for splicing if needed. Also the fuse block will be a nice update from the old ceramic fuses not to mention the wiring from the early 80s. |
Golten951
Golten951
Posted: Wed Oct 09, 2019 5:13 pm Post subject: |
cant wait to see this thing done _________________ https://www.the924.com |
Golten951
Posted: Thu Oct 10, 2019 2:08 pm Post subject: |
Thanks Morghen, it has been a lot of work! But will be epic! |
Golten951
Posted: Tue Nov 05, 2019 6:14 pm Post subject: Update |
Bit of a thought update, I have been working through ideas and ways to have functioning AC and Heating in my 924. If I leave the stock set up, I will only be able to run Heat with no AC. So my plan is to adapt a 85.5 HVAC interior unit into the cabin. I managed to get the whole interior unit for free, with wiring so if it done not end up working out, there is no lose at all, just possibly a more costly way of getting AC. reason for this change is I have to mod the firewall to keep the engine at a good location and set back in the engine bay, this mod took away the room for the stock AC unit that normally sits in the passenger foot well. Once I can work on my swap in Dec, I can get a lot more practical information. |
Golten951
Posted: Thu Nov 07, 2019 12:14 pm Post subject: Switch and Stalk update |
Since I will have the A8 Interior wiring, I will be using the A8 Headlight switch, turn signal and wiper stalks, plus the Ignition switch and key. Will have to do a little custom fab work... but what has not been custom on this whole swap?? lol., will update more as I go. |
Golten951
