Posted: Mon Oct 07, 2019 7:06 am Post subject: |
Heat cycles and vibration is not your friend with bolts unless lock wired.
I use studs with hex so I can tighten them in before using lock nuts with the OEM sleeves to help with the heat cycles. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Posted: Mon Oct 07, 2019 6:14 pm Post subject: |
Sound weird, are you sure theres not a semi deteriorated gasket in there ?
I only torque mine ones, and then they are set. _________________ 1980 924 Turbo
chuck21401
Joined: 20 Feb 2005 Posts: 525 Location: Annapolis, MD
Posted: Mon Oct 14, 2019 6:22 am Post subject: |
Bolt 93112319700 and Sleeve 93112319900. At $85 I'm not sure I want to install these until I figure out why the bolts keep backing out and disappearing.
_________________ 1981 Porsche 931 w/S1 engine & g31 transmission. Water-cooled intercooler
chuck21401
Posted: Mon Oct 14, 2019 6:32 am Post subject: |
Cédric wrote: | Sound weird |
I was thinking the same thing...and after crawling under the car I have multiple suspects.
3 out 4 studs holding the turbo to the exhaust have gone missing.
1 of 2 bolts missing from turbo mounting bracket. (apparently there are four total...need to check on the other two)
This one is hard to see, but missing the 3rd bolt that connects the exhaust manifold to the turbo (I've already replaced the two bolts on the other side).
Posted: Mon Oct 14, 2019 6:58 am Post subject: |
Wow, more torque next time partner..
I think the turbo to block mount i supposed to have 4 bolts into the block isn't it?
When installing new studs I'd torque them into their holes a bit too.. _________________ 80 Turbo - Slightly Modified |
chuck21401
Posted: Mon Oct 14, 2019 7:14 am Post subject: |
I can replace the missing bolts on the turbo mounting bracket and the turbo to exhaust manifold....but what to do about the studs from the turbo to the exhaust? Would I have to remove the exhaust, install new studs, then tighten everything?
I checked the parts diagram...the studs are 90008105002 and the nut is N90073001 and that it is a lock nut. Some websites listed the studs as NLA but others seem to indicate they have them in stock. _________________ 1981 Porsche 931 w/S1 engine & g31 transmission. Water-cooled intercooler
chuck21401
Posted: Mon Oct 14, 2019 7:21 am Post subject: |
Fasteddie313 wrote: | Wow, more torque next time partner.. |
Some good news...the j pipe and wastegate nuts were all still tight when I checked them.
Quote: | I think the turbo to block mount i supposed to have 4 bolts into the block isn't it? |
Yeah, I think you are correct, I'm looking at the parts diagram and see that the bracket has four bolts...I need to look under the car again...hopefully the other two have not gone missing.
Quote: | When installing new studs I'd torque them into their holes a bit too.. |
So that's the question...can that be done without disassembling everything either with a stud installer or the double nut trick? _________________ 1981 Porsche 931 w/S1 engine & g31 transmission. Water-cooled intercooler |
Posted: Mon Oct 14, 2019 8:12 am Post subject: |
Well.. To me logic would suggest that if they had room to fall out then they should have room to go back in..
And they are just studs.. Prolly M10X1.5 or something like that, find a nut that fits them and take that to match up..
Get some from the hardware store, black ones which are probably grade8..
I wouldn't be concerned with getting whatever the Porsche part numbered ones are..
I would definitely try it without removing the exhaust but it might be tricky.. _________________ 80 Turbo - Slightly Modified |
Posted: Mon Oct 14, 2019 5:30 pm Post subject: |
Get high grade studs with a hex end so you can torque them down tight with an Allen key. Use lock nuts on the exhaust parts. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Posted: Mon Oct 14, 2019 7:07 pm Post subject: |
I cant do mine on the turbine outlet without backing the exhaust. It looks strange that there are washers under the nut on the turbine outlet, those studs look home made aswell. I use lock nuts copper coated from the VAG catalouge there, they never back out and are cheap.
One things i noticed is that you have the old type gasket on the outlet, which you shouldnt have, if you have an s2 with the later turbine housing. Then the next question is what type of gasket is it in the turbo to manifold joint, it might be the old type there aswell, if it is its definitely blown out, so you will probably re torque those bolts very frequently until you get a fresh and correct gasket in there. The gasket should be like a small steel ring which sits in a groove. Seems like the turbo was changed and everything didnt really come together as it should have been done, neither correct hardware or torque/torquing sequence. There is a certain sequence how everything should be torqued together aswell, if you dont have it I can send it. _________________ 1980 924 Turbo
Posted: Mon Oct 14, 2019 7:55 pm Post subject: |
Cédric wrote: | I cant do mine on the turbine outlet without backing the exhaust. It looks strange that there are washers under the nut on the turbine outlet, those studs look home made aswell. I use lock nuts copper coated from the VAG catalouge there, they never back out and are cheap.
One things i noticed is that you have the old type gasket on the outlet, which you shouldnt have, if you have an s2 with the later turbine housing. Then the next question is what type of gasket is it in the turbo to manifold joint, it might be the old type there aswell, if it is its definitely blown out, so you will probably re torque those bolts very frequently until you get a fresh and correct gasket in there. The gasket should be like a small steel ring which sits in a groove. Seems like the turbo was changed and everything didnt really come together as it should have been done, neither correct hardware or torque/torquing sequence. There is a certain sequence how everything should be torqued together aswell, if you dont have it I can send it. |
Same here, I cannot get the two lower nuts off the turbo to exhaust flange without pulling the exhaust back. No way could I get a stud in or out with exhaust on.
Old exhaust, now using custom stainless but similar fixings
Untitled by stevenmcooper, on Flickr
As for manifold to turbo joint, I have never used the later fire ring and not blown out a gasket. But I do use new gaskets.
Quality hardware is a must to avoid breakages, backing out and leaks...
Fresh studs and lock nuts going in earlier this year when upgrading the turbo...
Untitled by stevenmcooper, on Flickr _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
chuck21401
Posted: Tue Oct 15, 2019 12:52 am Post subject: |
One things i noticed is that you have the old type gasket on the outlet, which you shouldnt have, if you have an s2 with the later turbine housing. Then the next question is what type of gasket is it in the turbo to manifold joint, it might be the old type there aswell, if it is its definitely blown out, so you will probably re torque those bolts very frequently until you get a fresh and correct gasket in there. The gasket should be like a small steel ring which sits in a groove. |
It's coming back to me now. When I reinstalled the exhaust the last time, I wasn't able to start one or more of the nuts without shifting the exhaust back at least a 1/4 inch. From the older thread:
Again from the older thread, yes, had washers and regular nuts. One of the studs came out as I dissembled everything.
Here is the turbo:
k26-2664 G4.10 So I believe the turbo is 1980.
The car is a 1981 931 but the engine and transmission are 1980. Except it has a the S2 charge tube.
I remember the gasket between the turbo outlet and the exhaust, it did have small steel ring. I have no idea what type of gasket is between the turbo and the exhaust manifold. Getting to that gasket might be a challenge. Shoot.
Quote: | Seems like the turbo was changed and everything didnt really come together as it should have been done, neither correct hardware or torque/torquing sequence. There is a certain sequence how everything should be torqued together aswell, if you dont have it I can send it. |
I found this...but it only covers re-installation of the turbo. The info I have about removing/re-installing the WG doesn't lay out a sequence on how everything should be tightened down....so if you have more info that would be helpful.
chuck21401
Posted: Tue Oct 15, 2019 1:13 am Post subject: |
Carrera RSR wrote: |
I can see why that is important now. _________________ 1981 Porsche 931 w/S1 engine & g31 transmission. Water-cooled intercooler |
chuck21401
Posted: Tue Oct 15, 2019 2:20 am Post subject: |
Carrera RSR wrote: | Get high grade studs with a hex end so you can torque them down tight with an Allen key |
Very nice. Source? I'm searching around and can't seem to find anything like those. What length?
Untitled by stevenmcooper, on Flickr[/quote] _________________ 1981 Porsche 931 w/S1 engine & g31 transmission. Water-cooled intercooler |
Posted: Tue Oct 15, 2019 2:55 am Post subject: |
chuck21401 wrote: | Carrera RSR wrote: | Get high grade studs with a hex end so you can torque them down tight with an Allen key |
I have no idea. I take old hardware to my local nut and bolt store and walk out with new equivilents. PET might give specs _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
