Porsche 924 Racecar Build Thread (AAN Conversion)
Goto page Previous  1, 2, 3, 4
PostPosted: Thu Sep 19, 2019 9:58 pm    Post subject: Reply with quote
Very nice work.
Now thinking about endplates for that splitter, instead of those dive planes...
'79 924 #77 ITB racecar
TJC
PostPosted: Fri Sep 20, 2019 1:01 am    Post subject: Reply with quote
Very impressive!
'95 BMW 318i/5 "Pearl"
'80 Porsche 924 Turbo...Save or Part?
'86 Porsche 944 Turbo...Parting, Not Much Left!
'87 Porsche 944 NA "Liebchen"
Still on the Prowl!
www.ttrs1.com
Britain
PostPosted: Fri Sep 20, 2019 1:38 am    Post subject: Reply with quote
924RACR wrote:
Very nice work.
The diveplanes were a last second "bullshit" generator
In the end, the front-end felt very stable. Those diveplanes don't extend past the front tires which stick over very far. I agree, things could be better...and I will make some changes.
-Britain
PostPosted: Tue Oct 08, 2019 3:09 am    Post subject: Reply with quote
Saw in one pic that you are using a very small brake booster and single master cylinder. I have the 944 brakes, MC and booster and would love to have a smaller booster as I could really use the additional space. A 924 7" MC will fit with a spacer to get the rod length right. Could I ask what you are using? I realize your entire system is much bigger. Pedal pressure is not an issue.
Mike
'77 924
cricketdesigns.com
Britain
PostPosted: Tue Oct 08, 2019 3:50 am    Post subject: Reply with quote
I am using a stock vacuum booster with a 944 master cylinder. Pedal pressure is perfect, even with the 996 calipers I am now running.
-Britain
PostPosted: Fri May 15, 2020 5:01 am    Post subject: Reply with quote
I can't believe I missed this thread..
That is some absolutely amazing chassis work..
Britain wrote:
After several years of blowing up 931 engines, we finally decided to do an engine swap to an Audi AAN 5-Cylinder.
What happened to the 931 engines? For what reason did they keep blowing? How were you running them?
PostPosted: Fri May 15, 2020 6:16 am    Post subject: Reply with quote
I'm reminded to ask - what drove you to rotate the throttle body on the 931 engine 90 degrees? Looking to do similar IC pipe routing on my street car with the EFI conversion and IC install, but I don't see anything that would drive that (yet)...
Britain
PostPosted: Sat May 16, 2020 2:56 am    Post subject: Reply with quote
The stock engines were running on the ragged edge for 8+ hr races. The combination of wanting/needed more power and running them hard for so long made for blown engines. I am sure that we could of spent large amounts of money trying to make things better, but they don't flow that well, they don't cool that well, and they vibrate to all hell. The more modern Audi 5-cyl fixes a lot of those problems.
Britain
PostPosted: Sat May 16, 2020 2:57 am    Post subject: Reply with quote
On the original 924 engine, I was using the S2 intake manifold to get the round throttle body mount and I was using a Subaru 2.0L throttle body. I needed it to face that direction because that was the way the throttle cable mounted.
PostPosted: Sat May 16, 2020 3:49 am    Post subject: Reply with quote
Well I just discovered another reason today why you might want to rotate it! LOL
Made a pretty little welded aluminum adapter plate to bolt on the Volvo TPS to the S2 throttle body. Then I bolted the throttle body onto the intake... only to realize that the TPS was hitting the intake, and I'd never get the connector on it!
So I shortened the shaft and simplified my mounting plate to be 1/4" thinner, clear of the intake.
Page 4 of 4
