Vacuum advance distributor hose, where does it go?
Goldwolf
PostPosted: Sat Oct 05, 2019 12:18 pm    Post subject: Vacuum advance distributor hose, where does it go? Reply with quote
I removed my AAR to check a hard starting issue, my AAR is stuck closed, even after visiting the freezer for about 10 minutes. On the search for one of those. But while I was in there I noticed this small piece of hose off the back of the vacuum advance unit of the dizzy. Where should it go? looks like it broke off. Its a side shot, but the cloth braided hose stops where it is in the pic.
Pic of my AAR for fun.
1981 Weissach Edition #179
Savethe924.com
Goldwolf
PostPosted: Sun Oct 06, 2019 11:59 pm    Post subject: Reply with quote
Is that a vacuum retard line? I'm trying to look at parts pictures and they don't seem to have it.
Savethe924.com
Goldwolf
PostPosted: Mon Oct 07, 2019 1:29 am    Post subject: Reply with quote
I found it, it helps having a stream of consciousness on this board.
My plastic hose was poking down behind stuff. Still need an extension because the braided part is not long enough.
You can see the white plastic hose in the back
Overview
My shock rubber mounts need replacing
Savethe924.com
