Goldwolf
Posted: Mon Sep 30, 2019 2:06 am Post subject: metal or aluminum sunroof latches? |
Any aftermarket latches available? I have been searching. I need the front ones.
Would prefer metal, but anything is better than $300 for some latches. _________________ 1981 Weissach Edition #179
Savethe924.com |
Joined: 14 Dec 2004 Posts: 1104 Location: Chicago-ish
Posted: Mon Sep 30, 2019 4:23 am Post subject: |
This is one of my pet projects. Have the actual latch handle part 3D printed and functioning in a 924S for a year but I want to tweak the clip part. I'll get some pics up _________________ 1980 931 since 1989
Joined: 08 Jan 2010 Posts: 2197 Location: Somerset, UK
Posted: Mon Sep 30, 2019 5:09 am Post subject: |
$300!! ......€100 each for the whole front catch.
Which bit snapped? Usually its only this part ...... https://www.rosepassion.com/en/cat/porsche-924-1980-924-turbo-coupe-manual-gearbox-5-speed/M351/bodywork-seals-and-rubber-elements/B2342/schemas/roof/I1150/bearing-bracket/P8318 _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Goldwolf
Posted: Mon Sep 30, 2019 5:47 am Post subject: |
Hopefully I am think about this wrong.
I am missing the levers? Also, does the deflector go "inside" the sunroof when putting it on? I need a deflector hinge too.
[/img] _________________ 1981 Weissach Edition #179
Savethe924.com |
Goldwolf
Posted: Mon Sep 30, 2019 11:34 am Post subject: |
I found 1 lever in the glove box! I think I just need another lever and the triangle repair plates. Metal brackets are present. _________________ 1981 Weissach Edition #179
Savethe924.com |
Posted: Mon Sep 30, 2019 5:36 pm Post subject: |
Triangle plates are listed in my previous post. Can be bought from Porsche or Rosepassion for €2 each. Deflector hinge can be had from Porsche too. Or you can pay more by buying second hand from Ebay.... _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Goldwolf
Posted: Mon Sep 30, 2019 11:20 pm Post subject: |
Thanks, the plastic stuff is pretty easy to locate.
I was just hoping their was some aftermarket aluminum. Seems like it could be done easy enough. _________________ 1981 Weissach Edition #179
Savethe924.com |
Posted: Mon Sep 30, 2019 11:37 pm Post subject: |
I'll see what I can come up with in aluminum if nothing can be found. Easy enough
Also inside the sunroof is a ridiculously heavy steel bracket. That will be made some other way as well _________________ 1980 931 since 1989
