Fuel distributor lines rebuilding
jeneese
PostPosted: Sat Aug 10, 2019 4:27 am    Post subject: Fuel distributor lines rebuilding Reply with quote
All the flexible joints on the steel fuel lines going to or leaving the fuel distributor are in shreds, including the 4 injector lines. Does anybody out there offering a rebuilding service for this well known issue?
Jim
Porsche 1982 Euro Spec 924
PostPosted: Sat Aug 10, 2019 4:52 am    Post subject: Reply with quote
You’ll find the rubber outers have perished but the inners will be just fine.
jeneese
PostPosted: Sat Aug 10, 2019 5:06 am    Post subject: Reply with quote
Maybe but since I am doing a complete engine overhaul I want to do it right the first time.
Thanks for your reply.
Jim
safe
PostPosted: Mon Aug 12, 2019 8:11 pm    Post subject: Reply with quote
Yes, the inner plastic lasts forever.
PostPosted: Mon Aug 12, 2019 10:47 pm    Post subject: Reply with quote
I got mine from http://www.unobtaniumsupply.com/
The stuff is called Cohline..
I have some stock left of the large feed from tank line in regular black and the medium return to tank line in braided stainless (so I don't melt mine again) I would like to pass on so if you want it let me know..
If you want all of your lines rebuilt or whatever I think you can get it all in regular black cohline, with or without the outer protection sleeves you are probably finding all split and cracked, or all of it in braided stainless..
If you don't want to do it and are looking for someone to rebuild the lines for you maybe I would do it..
You can get an idea of what the stainless line looks like in the blue link in my signature just below..
jeneese
PostPosted: Wed Aug 14, 2019 4:05 am    Post subject: Reply with quote
Thank you for the reply. Its all the lines attached to the fuel distributor, after the filter to the beginning but not including the body mounted return.
Not sure what I am going to do yet.
Jim
