Replacing or refurbing wastegate (Tial, perhaps?)
bureau13
PostPosted: Sat Jul 13, 2019 1:11 am    Post subject: Replacing or refurbing wastegate (Tial, perhaps?) Reply with quote
I haven't confirmed it yet, but I'm pretty sure my overboosting is due to a bad wastegate. I'm a little afraid of taking it off and snapping off one of those studs I keep reading about.
First off, the studs usually break off in the wastegate body, right? I assume the procedure is to remove the J-pipe and then pulling it off the other exhaust pipe (not sure what that one is called) and the mounting bracket...or do I need to remove more of the exhaust?
Given the cost of a new wastegate diaphragm, etc I will very likely just buy a Tial and sell the original to someone who wants to rebuild it. The Tial comes with stainless steel bolts. Can I use those on the 931 instead of stock studs? Or do I need to use studs and nuts for this application?
Final (ha!) question: Do I need to get the narrow body version, F46P, or does the standard F46 fit on these cars? I believe the only difference is the F46P has the fins machined down a bit to avoid hitting on some bits in the 930, the application for which it was originally designed. I just don't know if the 931 requires that.
1986.5 Silver 928S
2007 Hummer H3 (Daily Driver)
Past lives (I miss them all):
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
1987 RX-7 Turbo II (Sold)
1985 RX-7 GSL (Stolen)
PostPosted: Sat Jul 13, 2019 3:15 am    Post subject: Reply with quote
On mine I need to take all of the exhaust pipes off, including the J-pipe, but the turbo can stay...
I don't have 1st hand experience with a Tial but I think they were designed to be a direct fit replacement, but I don't know about the the signal line or its mount to the torque tube stuff though..
I broke about half the studs in mine..
I set it up on my drill press table by putting one of the remaining studs in my chuck to get it prefectly straight with the studs, then moved the table and drilled the other studs out till I could see some threads, then put the correct tap in my chuck still perfectly straight and turned the chuck by hand with a little bar to tap the holes out perfectly straight down.. Worked..
PostPosted: Sat Jul 13, 2019 3:16 am    Post subject: Reply with quote
Aren't Tials in the region of $600? A new diaphragm, if needed, is $150. I'd put the extra money into an inter/charge cooler and use the boost more efficiently. a Tial will add nothing to the car or performance, but will take a lot of $ from your bank balance.
bureau13
PostPosted: Sat Jul 13, 2019 5:00 am    Post subject: Reply with quote
I commonly see them for around $480, but your point is still valid. That's a lot more than $150. I see a lot of them on Ebay for close to the price of the Tial (or even more) but they're probably not in need of a rebuild, and being listed and being sold are two different things. The main factor was I see folks talking about valve guides or something in the wastegate that had to be machined or something? That's outside of my skill set for sure, and I'm not sure I'd know by looking at it if such a thing were needed.
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
PostPosted: Sat Jul 13, 2019 5:07 am    Post subject: Reply with quote
You used to have to get one of these made by a machine shop but it looks like you can just buy one now..
https://www.ebay.com/itm/Qty-1-Porsche-930-935-965-931-turbo-wastegate-essential-rebuild-kit/113813352340?hash=item1a7fcdef94:g:pj4AAOSw9~Jc4v7K
bureau13
PostPosted: Sat Jul 13, 2019 5:08 am    Post subject: Reply with quote
Also, what do you guys think about using a low-power impact driver on the nuts, at least those that can be reached that way? When I changed the water pump in my 928 I broke off a bolt, after which I used an impact driver and had no additional problems. I got to learn about Timeserts, which are cool, but I don't want to learn about them again...
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
bureau13
PostPosted: Sat Jul 13, 2019 5:46 am    Post subject: Reply with quote
Oh, that's good to know! Definitely takes some of the worry out of it for me...
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
PostPosted: Sat Jul 13, 2019 10:50 pm    Post subject: Reply with quote
The wastegates are extremely robust.....never seen one off a 924 that needed more than a new diaphragm and the usual broken stud, or two. Yes, there is a valve in there, but again I've never seen one that required a new valve guide. Certainly if you have one apart, I'd suggest you lap in the valve......a rudimentary task.
I've even rescued one from the trash (ex-930), which had a crack through the fins. This was welded up and the wastegate went on to lead a happy, long life doing what it was designed to do.
chuck21401
PostPosted: Sun Jul 14, 2019 12:17 am    Post subject: Reply with quote
I'm just about to start this project. Bought the valve guide and gasket kit on Ebay.
The Haynes manual has procedure to remove the wastegate and I found this online:
Not sure why the starter has to come off...but a good reminder to disconnect the battery before diving in.
Will post pics and progress updates on the other thread.
I messaged the seller of the valve guide kit; he used a hydraulic press to carefully remove the old valve guide. Well, I don't have one of those so will need to take it somewhere...but it will be a while before I get to that point.
1981 Porsche 931
PostPosted: Sun Jul 14, 2019 1:20 am    Post subject: Reply with quote
If you have to replace the valve guide (which I seriously doubt), any engine shop will be able to press out the old one and press in a new one.
chuck21401
PostPosted: Sun Jul 14, 2019 3:25 am    Post subject: Reply with quote
Thanks.
re: installation
This thread on Pelican discusses a neat trick...guide is frozen...hot side of WG heated in oven to 450 degrees...the new guide drops in....apparently.
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/972314-930-wastegate-rebuild-nla-parts-2.html
Hopefully the valve guide is fine...but I'm running out of suspects. Hopefully will know something new soon.
Also curious to find out what bureau13 finds...
1981 Porsche 931
PostPosted: Sun Jul 14, 2019 4:29 am    Post subject: Reply with quote
Youíll soon realise far more has to come off a turbo than you think with most maintenance jobs. Make sure you have spare fixing, gaskets, band aids, patience etc. Enjoy
bureau13
PostPosted: Sun Jul 14, 2019 3:26 pm    Post subject: Reply with quote
So the starter thing is confirmed? Good grief...it's on the other side of the engine lol. There must be something in the exhaust that has to come off that interfered with the starter? Although I just replaced my starter and I can't recall anything obvious...
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
PostPosted: Sun Jul 14, 2019 6:59 pm    Post subject: Reply with quote
No. The starter is right next to the exhaust, j pipe and wastegate. You need spanner and hand room. Removing the starter gives you this room. You may be lucky, I wasnít . I did this job a few months ago to replace my turbo.
bureau13
PostPosted: Mon Jul 15, 2019 2:03 am    Post subject: Reply with quote
Could this be a LHD vs RHD thing? My starter is on the (LHD) driver's side, and my wastegate is on the passenger side, as is the turbo.
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
