931 Tech To do list
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8
MOTANUL
PostPosted: Fri Jul 05, 2019 7:16 am    Post subject: Reply with quote
AC compressor is rebuilt.
Does anyone know if it's normal to lower RPM when the AC compressor works?
sold Porsche 924 NA 1979
MOTANUL
PostPosted: Thu Jul 11, 2019 9:24 pm    Post subject: Reply with quote
We did a general overhaul of the brake system (calliper gasket set, brake hose, brake lines).
The air conditioner works and the compressor is dry underneath.
bureau13
PostPosted: Sat Jul 13, 2019 1:27 am    Post subject: Reply with quote
Some cars actually kick up the revs a bit to make up for this (normal occurrence) either by introducing a small vacuum leak, or some electronic means in newer cars, but I can't remember if these cars do either. Mine does lower a little. Certainly, it should not lower to where it is threatening to stall or anything...
1986.5 Silver 928S
2007 Hummer H3 (Daily Driver)
Past lives (I miss them all):
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
1987 RX-7 Turbo II (Sold)
1985 RX-7 GSL (Stolen)
MOTANUL
PostPosted: Mon Jul 15, 2019 2:36 am    Post subject: Reply with quote
Mine drops about 100 rpm.
If both fans start lower other 50 rpm.
I had to increase the idle speed to 1100 rpm to be ok. In the worst case scenario, it drops to 950 rpm and the engine runs ok. (increased temperature and AC on, head light on, etc)
Page 8 of 8
