Juho
Posted: Wed Jun 12, 2019 5:05 am Post subject: Fuel lines? |
My car was converted to carburetors when i bought it now i am converting it to efi so i need to redo the return line. Where fuel return should be at the tank and how it should be routed to engine bay. |
Posted: Wed Jun 12, 2019 10:40 pm Post subject: Re: Fuel lines? |
Juho wrote: | My car was converted to carburetors when i bought it now i am converting it to efi so i need to redo the return line. Where fuel return should be at the tank and how it should be routed to engine bay. |
Originally the pressure and return lines go side by side on the left hand side of the torque tube. Up over the rear axle on the left side following the cross member in front of the tank, the my memory gets hazy after that but you should be able to take it from there.
I replaced mine and used 8 mm copper tubing from "Biltema", which is present i Finland I think? |
agfisher
Joined: 09 May 2007 Posts: 478 Location: West Hartford, CT
Posted: Thu Jun 13, 2019 2:24 am Post subject: |
The return line makes a turn across the bottom of the car right in front of the fuel tank where it switches to rubber. From there it goes down past the pump and connects to the bottom of the fuel tank. _________________ 1977 924 N/A Martini Edition |
