Brake Pedal Height Adjustment
tofuricer
PostPosted: Wed May 01, 2019 9:06 am    Post subject: Brake Pedal Height Adjustment Reply with quote
My '87 924S has been having a brake dragging issue. The pedal is really high and engages immediately when I press on it. I can hear and feel the brakes dragging, mostly the rear. The e-brake is not engaged.
I am thinking that the P.O. adjusted the pedal so high that the calipers can't fully release.
However, I am looking at this yolk and nut and not sure how it works. Do I pull the pin and then rotate the whole yolk? The only way to get enough room to do that would be to bleed the brakes, but before I do that, I want to make sure I am
1) doing this right?
2) not missing something else I should be checking first?
Thanks!
1987 924S
PostPosted: Thu May 02, 2019 1:09 am    Post subject: Reply with quote
I'm guessing the calipers' sliders need cleaning.
PostPosted: Thu May 02, 2019 2:08 am    Post subject: Reply with quote
The actuating rod is a hex piece. Loosen locknut, rotate rod.
  • Shaggy (1980 931) - SOLD (unlucky, but tried hard )
