unsticking the clutch
Cole Thomas
PostPosted: Fri Mar 22, 2019 12:59 pm    Post subject: unsticking the clutch Reply with quote
I have a 1982 924 2.0 NA that hasn't been on the road since about 1991. The clutch is fused/rusted to the flywheel. What is the best way to get it unstuck without removing it? thank you for the responses in advance.
1982 Porsche 924 NA project
safe
PostPosted: Fri Mar 22, 2019 5:59 pm    Post subject: Re: unsticking the clutch Reply with quote
Start it with, drive it. While driving press down the clutch pedal and accelerate/decelerate to try and break it free. Do it on a piece of road with little or no traffic...
Ozzie
PostPosted: Mon Mar 25, 2019 9:46 am    Post subject: Reply with quote
Had this problem with the wifes Fiat and the only method that worked was jacking the rear end, start car in gear, depress clutch and hitting the brakes repeatedly.
Basically if you dont want to disassemble it need a jolt or lots of them
Its AUTO and its BLACK
Montego Black on black/red
Cole Thomas
PostPosted: Wed Mar 27, 2019 1:48 am    Post subject: Reply with quote
Thank you sir, I appreciate it and will try it.
