Clutch pedal not fully coming back 931
PostPosted: Mon Mar 25, 2019 6:41 am    Post subject: Clutch pedal not fully coming back 931 Reply with quote
My 931 wasn't used for 4 months. The clutch pedal was on the ground. After a few pumps it came back.
While driving it doesn't come back fully, and the clutch slips a bit.
What could it be, just air in the system, or a leaky cilinder ?
937 DITC
Johann
PostPosted: Mon Mar 25, 2019 7:00 pm    Post subject: Reply with quote
I had this a year or so ago. The slave cylinder was weeping causing the clutch to stay on the floor some times, but if I hooked it with my foot it would pop back up...until it didnít anymore. After replacing the slave cylinder, I could not get the clutch to come up fully. In the end I found that my master cylinder was also leaking just enough to make it lose pressure. After replacing the master, she is as good as new.
