Cole Thomas
Posted: Fri Mar 22, 2019 1:04 am Post subject: starting issues |
I am currently working on getting a 1982 924 2.0 NA running again after being off the road since about 1991. I have gone through all of the electrical parts to the car (new fuse block, fuses, etc.) I got all of the lights to come on in the car including dash lights, clock, oil pressure, and tail lights. I replaced the starter, water pump, and timing belt. I got the engine free and tried to start it, but the starter would not crank. When I put a voltage tester on the starter, I get 12.5 volts, but when the key is turned the voltage at the starter drops to zero. I dont think the clutch or the brake has to be pressed to start the car. I don't have any relays in the car yet. I also don't know if a starter wire runs through the fuse block. I just do not know what causes the lack of power to the starter. Thank you in advance for the responses, anything helps _________________ 1982 Porsche 924 NA project |
Harm
Posted: Fri Mar 22, 2019 2:55 am Post subject: Re: starting issues |
Try these:
As part of the wiring harness, but inside the car at the steering column, the white plastic ignition switch° at the steering column might be interfering.
It will block battery juice from flowing easily through the starter…
Replace it. See the How-to.
Another thing is your engine block needs to wear ground straps to complete the circle of voltage.
HTH
Regards,
Harm.
°It sits underneath your key. Most of these are cracked by now and are unable to support voltage when key is turned into the START position. |
Cole Thomas
Posted: Fri Mar 22, 2019 3:49 am Post subject: Re: starting issues |
Harm wrote: | Try these:
HTH
Regards,
Harm.
Thank you, I will try what you suggested. I have used contact cleaner on all of the fuses and terminals along with cleaning all of the grounds on the engine i could find. I did clean the two white plastic plugs that are on the back of the ECU as well. _________________ 1982 Porsche 924 NA project |
Posted: Fri Mar 22, 2019 4:40 am Post subject: |
With the car in neutral, carefully use a screw driver to connect the two large terminals on the starter and see if it cranks. If not the issue is not the ignition switch.
Are you sure you have a good fully charged battery?
With the headlights on, try to start it. Do the headlights dim? _________________ White 87 924S "Ghost"
Cole Thomas
Posted: Fri Mar 22, 2019 5:55 am Post subject: |
Paul wrote: | With the car in neutral, carefully use a screw driver to connect the two large terminals on the starter and see if it cranks. If not the issue is not the ignition switch.
With the headlights on, try to start it. Do the headlights dim? |
Thank you. I am sure the battery is fully charged, I will try what you suggested thank you for the response. Much appreciated. _________________ 1982 Porsche 924 NA project |
