Clutch Cable Adjustment
PostPosted: Tue Mar 05, 2019 10:46 am    Post subject: Clutch Cable Adjustment Reply with quote
The Haynes manual says "adjust the clutch cable to 138mm +-2 from the lever point to the bottom of the adjustment bracket". It then shows a diagram with the 138+-2 to th bottom of the lower adjustment washer. Which should I go for, the bracket or the washer?
Mike
'67 MG Midget Dp
PostPosted: Wed Mar 06, 2019 11:41 pm    Post subject: Reply with quote
I found Gohim's old method. Adjust the freeplay in the clutch lever to 1/4" and it is good to go. I seems to work although the clutch pedal is now higher than the brake pedal.
Mike
'67 MG Midget Dp
