Any custom exhausts available for 931?
Goto page Previous  1, 2, 3  Next
PostPosted: Thu Oct 25, 2018 12:34 am    Post subject: Reply with quote
Oooh. I'd be concerned about using lightweight/thin wall on a turbo exhaust, especially right at the turbo. I assume you're not going with inconel?
I'd probably want to use the heaviest gauge available, for durability... at least for the front half...
'79 924 #77 ITB racecar
PostPosted: Thu Oct 25, 2018 1:36 am    Post subject: Reply with quote
Yeah this is my dilemma... If I go with 0.035 right off the turbo it would be 321. I was thinking I might coat that too
I do agree that it probably should be 0.065 which would make it considerably cheaper and I could do it in 304
At the very least make it so the 3" down tube is its own separate piece just in case
1980 931 collecting dust
PostPosted: Fri Oct 26, 2018 5:36 am    Post subject: Reply with quote
My pipe is a stock gutted cat and a straight pipe replacing the muffler.. It's not all that loud..
That muffler was heavy.. It might get a pretty chrome tip some day..
I think the stock pipe is pretty damn good.. Quite a nice piece..
Maybe their are gains to be had by increasing the down pipe size? You think?
When? @ stock? 200hp? 250hp? 300hp?
I don't imagine increasing the downpipe size would help much until you are making enough power for it to start becoming a restriction..
What did the GTS have for a downpipe? I'm pretty sure it had the same manni-turbo-J-WG setup but did it have a bigger downpipe?
PostPosted: Sun Oct 28, 2018 3:37 am    Post subject: Reply with quote
Its popular to put in a larger down tube to get the turbo to spool sooner but its also based on space restrictions to not carry that larger section all the way out
Stock is actually good and for most of us just fine. Supposedly 2.5" is good up to 250HP and 3" too small for 400+. I wouldn't even mind taking out the flattened sections and putting in a lighter muffler
I am just trying to put something lighter into the '82 since I have to do something anyway (due to all the damage and poorly repaired sections).
PostPosted: Sun Oct 28, 2018 7:31 pm    Post subject: Reply with quote
The GTS is almost the same set up as stock RoW except the centre silencer/muffler was deleted
K-Roll931
PostPosted: Tue Feb 05, 2019 4:11 pm    Post subject: Reply with quote
My 931 came with what I'm pretty sure is 951 rear section. But with one of support bracket welds cracked and/or broken at the muffler and base and one finger-length crack along the pipe, I'm willing to do a budget-friendly test if this can't be salvaged.
PostPosted: Tue Feb 05, 2019 5:42 pm    Post subject: Reply with quote
Looks like the correct 931 part to me.
Ruby-sh 924
PostPosted: Tue Feb 05, 2019 10:37 pm    Post subject: Reply with quote
We'll get it figured out, one way or the other, Karl!
I'd be down with trying out some alternatives; may just be a matter of identifying a suitable alternate rear chamber...
Then again, the simplest might even be just starting with trying a straight pipe in there. Just needs a sleeve joint, plus a little fabrication to match up with one of the stock hangar points at the back...
To just swap in a straight tube for the rear muffler, doesn't take too much more than getting a straight section from these guys:
https://catalog.woolfaircraft.com/viewitems/product-catalog/staight-tubes
They're just down in Romulus (though I ship, anyway, takes too long to get there).
K-Roll931
PostPosted: Thu Feb 07, 2019 8:52 am    Post subject: Reply with quote
That's what I'm thinking! I'm apprehensive of a straight pipe on the first go, however. I've heard that on the YouTube and it's way too loud for me, so some form of muffler is gonna have to stay back there. But whoever and however this was done, I like this one!
https://www.youtube.com/watch?v=_OHH-AMlxVo
'80 931 M471 - Dolomite Gray -> Monaco Blue
PostPosted: Thu Feb 07, 2019 1:03 pm    Post subject: Reply with quote
The one on youtube in my signature?
It is honestly pretty quiet in the car and much quieter in general than a non-turbo straight piped car.
I had a 318is that was wayy louder with a glasspack.
I had to put inline a 2nd glasspack after the 5th or so time I got pulled over they finally gave me a ticket for it, and the cops still almost wouldn't pass it with 2 glass packs but it barely passed their meter with me being very ginger on the throttle
Here is the same straight pipe as my sig video flat out @ 15psi of boost from in the car on a very early run of mine.. https://www.youtube.com/watch?v=REaoapuzrzY
Well, I have drove some pretty darn loud stuff so "quiet" to me is subjective.
I find it quite quiet in the car due to the exhaust being past the rear bumper, and the turbo quiets the engine a lot, about equal to a cat I'd say.
Definitely quiet compared to a car with a broken exhaust anywhere under the floorboard, lol..
The one you linked a video to sounds like a motorcycle to me and you can't hear the turbo whistle at all..
I love the turbo whistle "SHHWEEETT SHHHHWWWEEETT" sound in my exhaust while the turbo is still spinning slow enough to be within audible range, and the "agricultural" musclecar-esque-ness of it seems period correct to me, fitting.
I think you get more turbo sound with a bigger turbo too because it stays within audible range before it spools up more..
I got my "custom" exhaust here https://www.youtube.com/watch?v=x_L9dm8uH94&t=99s
That is a slightly craked OEM exhaust, right before the muffler, and is way louder in the car than the straightpiped 931..
My M3 is probably only slightly quieter with its cats straightpiped and OEM catback muffler..
Here is a video of it trying to diagnose a slight idle miss I fixed..
https://youtu.be/0eS4VDeU81g?t=65
Revs at 1:05
That car sounds sick (as in great) in it's own way that is not really comparable to the 931.
A straight pipe is basically free DIY. I'd say you should atleast try it. Experimenting is fun.
K-Roll931
PostPosted: Thu Feb 07, 2019 1:13 pm    Post subject: Reply with quote
I had to put inline a 2nd glasspack and the cops still almost wouldn't pass it but it barely passed their meter
I find it quite quiet in the car due to the turbo and the exhaust being past the rear bumper.
I love the turbo whistle "SHHWEEETT SHHHHWWWEEETT" sound in my exhaust while it is still spinning slow enough to be within audible range and the "agricultural" musclecar-esque-ness of it.
Yours was actually my reference for muffler delete haha. I love the sound, I was just worried about how loud. I reckon it wouldnít hurt to try since it is free. I did try it on my Ecoboost Mustang and didnít think that was overly loud. Maybe thatíll be the same here.
The absolute loudest I think I can handle for this car is Carrera GTS loud.
https://youtu.be/LeEGCQ8tM3o
PostPosted: Thu Feb 07, 2019 2:35 pm    Post subject: Reply with quote
If you make the straightpipe long enough to just barely stick past the rear bumper I think that is the key to it being quiet in the car.
Get the noise past the underside of the car and it is plenty quiet cruising around.
The GTS seems quite loud and you can hear the turbo in the exhaust like I was saying (while it is smoking) but it appears to have a can of some sort in the muffler position.
My 931 in all the videos is straightpipe catback with a gutted cat.
I think it isn't loud enough for the cops to be bothered.
I don't feel as if my stock downpipe and exhaust will hinder my performance goals so it is not something I plan to upgrade but maybe tidy it up a bit.
I think it will do to 20psi and that will be plenty..
I think exhaust could get you another 10-20 HP @ high boost sure, but if you don't already have a gutted cat, an intercooler, and running 13psi or better I don't think it will get you much of anything.
Maybe it will spool faster but it doesn't bother me that it doesn't get full boost until 2.9-3k rpm. It is the character of the car like a 2-stroke powerband and I love it. It's wild..
Best bang for your buck upgrade? Intercooler.. No question..
I understand wanting a $1,000+ exhaust for your beautiful car but that's just not me..
I prefer the "Yeah, I made that" kind of cool..
BassGT's exhaust however is another level of cool, 2nd kind of cool (as nutnfancy says), that is epic history cool..
I have ledfoot's boostgauge
I would love even a switch from BassGT's car.
PostPosted: Thu Feb 07, 2019 10:24 pm    Post subject: Reply with quote
My recommendation is no muffler until the back end of the pipe. You want quicker gas flow off the turbo only suppressing the noise at the end of the pipe. It will give you quicker spool and the potential additional power will be from spooling earlier. Its also far easier to cut off/weld on differing sizes of muffler to tune the noise to your taste. No muffler at all sounds awful. I did it. Far too much noise which was not a nice noise.
Absolutely. #1 priority if you want a little to a lot more power
That exhaust is on my car......
2nd bit of cool is I now have Morghens K27/26 hybrid turbo to install soon from his GTS wannabe. Will be awesome with all other mods on my car to support its bigger compressor
PostPosted: Thu Feb 07, 2019 10:46 pm    Post subject: Reply with quote
I'm pondering throwing one of these on the back:
https://www.jegs.com/i/Dynomax/289/24215/10002/-1
We use them on the 924 NA racecar to good effect, and I know they've held up very well on that car through countless seasons of racing. Of course, a turbo has a hotter exhaust... but OTOH if it's only at the very back...
They're also definitely higher quality and longer-lasting than your typical glasspack. Just have to find a nice-looking tip.
I like gutted cat, easy and cheap... though it's also not so hard to just splice in a straight section, admittedly. Biggest pain would be just joining back in the wastegate exhaust, if you don't re-use any of that plumbing...
Looking forward to putting something like this behind my soon-to-be-rebuilt turbo unit... sometime this spring...
Karl also pointed out a Magnaflow muffler that looks like it might be better than the above Dynomax, a little quieter/more streetable, yet still a straight-through - just more volume to absorb...
https://www.amazon.com/MagnaFlow-Exhaust-Products-10425-Muffler/dp/B000XQO0UW
K-Roll931
PostPosted: Thu Feb 14, 2019 4:28 pm    Post subject: Reply with quote
My new plan is to gut the cat and run the exhaust as such to start. If I need to go louder, I'll go from there. Just need to finish getting my car back together first!
Page 2 of 3
