1980 Porsche 924 turbo aesthetic restoration mainly
Goto page Previous  1, 2, 3
PostPosted: Thu Jan 03, 2019 7:04 pm    Post subject: Reply with quote
The images above for the clutch and pressure plate appear to be showing a rubber damped clutch and deep pressure plate. This is a series 2 set up. The series 1 set up for a spring damped clutch, the S1 pressure plate is now nla and replaced by the 911/915 plate. Make sure you buy the right components or make sure they are interchangeable with S1 and S2 set ups. Your car should be S1 spec, but a few things on it are S2 spec - oil breather, turbo. So don't assume until double checking that the motor hasn't been swapped out in the past.
(S1 and S2 have different flywheels, clutch, pressure plates)
PostPosted: Thu Jan 03, 2019 10:01 pm    Post subject: Reply with quote
The clutch is a spring clutch on that car, woolie changed the clutch when the car was still in UK. Engine is the original S1.
red 924 and not red 924
MOTANUL
PostPosted: Tue Jan 08, 2019 1:09 am    Post subject: Reply with quote
This WE.
I will leave the current topic only for pictures and non-technical discussions.
I will post the "to do list" in the area "931 Tech."
sold Porsche 924 NA 1979
MOTANUL
PostPosted: Mon May 20, 2019 6:12 am    Post subject: Reply with quote
Pics
PostPosted: Mon May 20, 2019 5:44 pm    Post subject: Reply with quote
Great to see that car doing well.
Page 3 of 3
