Dan_G
Joined: 06 Dec 2018 Posts: 4 Location: Myersville, MD
Posted: Fri Dec 07, 2018 1:22 pm Post subject: 1982 931 RallyCross Build |
Just picked up this 1982 931 as a Rallycross build. So far looks like a very solid chassis that is cosmetically challenged. It currently doesnt run but the engine will turn over, probably needs a clutch master and slave, and most likely rubber brake lines and possibly a master. Interior is bad but will be getting trashed.
Everything looks like it was there, hasnt run in 5-10 years last owner said it had some fuel delivery problems.
The goal right now is to get it running and idling then get it into proper mechanical condition, dont care much about cosmetics as it will be getting properly used off road anyway. The second I have it running its getting a timing belt, just want to confirm it runs before doing the work.
I currently have a 1986 944 so I have some knowledge of the chassis and early offset suspension but almost everything is different in one way or another.
Last years rallycross car and hopefully next years backup. 1984 BMW 318i
Posted: Fri Dec 07, 2018 5:18 pm Post subject: Re: 1982 931 RallyCross Build |
Dan_G wrote: | The second I have it running its getting a timing belt, just want to confirm it runs before doing the work. |
Timing belt first!!
Dan_G wrote: | hasnt run in 5-10 years |
Don't even crank it anymore before you put a new timing belt on it.
This is NOT like a 944 engine where the timing belt and work are very complex/expensive but will still destroy your engine.
The timing belt for this car is like $10-$20 and the tensioner is like $7.50, and it only takes like 20 minutes with no specialty tools. Super easy. Gorilla can do it.
1st do the timing belt then start at the back of the fuel system unless you have already checked the fuel quality somewhere, where?
Drain the tank/pull the intank fuel pump - super easy.
12v to that pump and see if it works. Yes=good No=replace with another pump or 944 screen setup.
Fresh fuel and tekron injection cleaner stiff mix. 1 botttle 1/4 tank ish
Inline fuel pump 12v, does it work? If no replace.
Take the fuel supply line off of the fuel distributor at the banjo bolt and put in something. Jump the fuel pump power 30-87 on fuel pump relay. Clean? Hope so..
Replace fuel filter.
Put it back together and jump the pump again. Do an injector flow test as outlined in the haynes manual or search.
Problems? Post em..
If everything is good up to this point try to start it but if you run it hard (boost) without doing a proper CIS pressure test you might blow it up.
Buy/build a CIS fuel pressure tester, easy, google search "site:924board.org cis pressure test" ""site:924board.org how to operate hoffman" or follow instructions in haynes.
Problems then post..
Get through that and you can run it hard.
If your mechanicals and ignition are sound then next you need an intercooler
Ofcourse change the oil, check coolant, etc. _________________ 80 Turbo - Slightly Modified |
Dan_G
Posted: Sat Dec 08, 2018 1:43 am Post subject: |
Thank you will be doing timing belt first. Haven't turned it over with the starter yet.
Where are the top dead center marks on this car? |
Posted: Sat Dec 08, 2018 6:27 am Post subject: |
TDC mark is viewed through a window in the bell housing, its to the left of the brake booster.
_________________ White 87 924S "Ghost"
Dan_G
Posted: Sat Dec 08, 2018 1:48 pm Post subject: |
Thank you,
I now have plugs, wires, cap, rotor, air filter, fuel filter, oil filter, timing belt, and tensioner on the way. |
Posted: Sun Dec 09, 2018 6:51 am Post subject: |
When I read “rallycross” a 924 is not something that enters my mind.....
https://youtu.be/TbD6MbHX26s _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Dan_G
Posted: Mon Dec 10, 2018 11:37 am Post subject: |
SCCA rallycross, think offroad autocross |
