Raize
Posted: Thu Oct 04, 2018 9:24 pm Post subject: Lost keys |
I lost the only keys for my 924. I can pry the door to get in, but still no key to start it.
What's the easiest cheapest and quickest route to being able to start it with a screwdriver or button and turn off the steering lock. I don't care if it involves permanently breaking the ignition lock or steering lock. I just need this car driveable as it is my only transport and I have no money right now.
Getting a locksmith to make a new key or more likely replace the locks is not an option as it'll be more than the car is worth. |
Qik Nip
Posted: Fri Oct 05, 2018 12:15 am Post subject: Re: Lost keys |
Raize wrote: | I lost the only keys for my 924. I can pry the door to get in, but still no key to start it.
Sounds bad Mate. And my input isn't going to make it better. To remove the steering lock, you have to first turn on the key (to retract it the pin) and then it can be disabled. I fear your only recourse is that locksmith. I hate being the bearer of bad news. _________________ '79 NA 924 Land Speed Car
Great Lakes SCCA SM points champion '09,'10,'11 |
Raize
Posted: Fri Oct 05, 2018 1:23 am Post subject: |
That's unfortunate. Plan B then.
I managed to remove one of the locks, so in theory a key could be cut to fit it. However with the lock off the car I doubt any shop will touch it. And mobile call out is too expensive.
I have read some online guides and it doesn't sound particularly hard to "impression" a new key from the lock I have myself.
Could someone please measure the dimensions of a 924 ignition key so I know what size of key blank I need? |
Raize
Posted: Fri Oct 05, 2018 1:44 am Post subject: |
I've disassembled the fuel filler cap so now I just have the lock barrel inside a white plastic moulding.
Is there any way to see the wafers now without destroying this thing? |
Raize
Posted: Fri Oct 05, 2018 2:15 am Post subject: |
It just pulls out. Now I can see all the wafers and easily cut a key to fit once I find some blank.
Actually kinda terrifying how easy this was to do. Gonna fit a hidden kill switch on my car once I get the key problem sorted 😬 |
Ozzie
Posted: Sat Oct 06, 2018 8:11 am Post subject: |
Locksmiths used to be able to cut a key from a number on the barrel.
Not sure this practice worked on 924 or is still in use. _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
Raize
Posted: Wed Oct 17, 2018 7:04 pm Post subject: |
Still haven't solved this. Its easy to duplicate any key but the ignition without even using a proper blank. But the ignition lock has a different wafer layout.
I've learned to impression locks to try to make a working ignition key however it didn't work.
Does anyone have information on the number / spacing / layout of the tumblers in the ignition lock barrel? I had seven impression marks on the key I tried to make but I think there may be more tumblers than that, especially towards the end of the key the features seem more complex. |
Eliza
Joined: 17 Aug 2015 Posts: 174 Location: Prov. Utrecht, The Netherlands
Posted: Mon Oct 22, 2018 10:15 pm Post subject: |
Hello Raize,
if you're still looking to solve this, pm me. I can send you a couple of photos that may help ( ignition lock cylinder and tumblers off of my car, taken a few months ago while cleaning ).
Eliza _________________ 1985 924 NA RoW
1981 931 S2 RoW |
scm924s
Joined: 22 Oct 2010 Posts: 264 Location: Gloucester UK
Posted: Fri Nov 02, 2018 6:42 am Post subject: |
Normally the ignition/door/hatch and fuel cap are identical keys, an early VW Beetle or Golf blank is the same, so the ignition key shouldn't have any different features to a door lock key. Always assuming all the locks haven't been changed somewhere. _________________ 1984 n/a Ruby Red Metallic
1988 924S Guards red- sold
1986 924S Guards Red - sold
1984 n/a Black - sold
1980 n/a Le Mans#1 - sold
1980 n/a Le Mans#2- sold
1977 Martini - sold |
