G31 Definitive Rebuild Parts List
Kenodog
PostPosted: Thu Aug 23, 2018 12:27 pm    Post subject: G31 Definitive Rebuild Parts List Reply with quote
Anyone have one ? I tried looking this up but after a few hours of searching just became confused by the differences between G31 / 901 / 915 / 928 parts. I know there have been many people that have used different components from both the 911 and 928 world.
My question is does anyone have a definitive list of the parts needed to rebuild a G31 as fully as is possible with the limited bits still available new ? Syncho PNs and quantities, dog teeth gears, sliders, rings etc. ?
Olive's transmission was rebuilt by the PO but something inside is not right. After a half hour of driving when the box warms up she gets a hum. I changed the fluid to a good synthetic and when I pulled the drain plug (magnetic) it was full of metal. Fudge. Since I have a factory LSD unit to swap in I will take it into Weissach here to be rebuilt and the LSD installed but would like to provide them with all of the needed parts, gaskets etc. so they don't install anything they shouldn't. . .
TIA,
Leigh
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
Ian89C4
PostPosted: Sat Aug 25, 2018 12:10 pm    Post subject: Reply with quote
Subscribed!
I also have the hum over 60mph. Front input bearing also rattles at idle.
Running Royal purple...three changes later. Would love rebuild as far as possible.
Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala")
kevingross
PostPosted: Wed Oct 17, 2018 12:00 pm    Post subject: Reply with quote
Hi Leigh, great chatting with you today! I found the following link to Peter Tinucci's excellent article posted on Ideola's Garage:
http://garage.ideola.com/downloads/G31-Trans-Updated-20100207.pdf
And this one still available from flussigmagazine:
http://flussigmagazine.com/der-houmlhepunkt/g31-transaxles-016083-transaxles-and-01e-supplement
Kevin
Catellus Engineering, Inc.
http://www.catellusengineering.com/
catelluseng@gmail.com
Kenodog
PostPosted: Thu Oct 18, 2018 12:57 am    Post subject: Reply with quote
Thank you Kevin. I am going to do some more research and see if I can nail down what is still available (for now). Then I'm going to stock up because this stuff never gets cheaper or easier to find !
Leigh
1981 931, Sabine
2024 KLX300
2024 KLX140
Kenodog
PostPosted: Sat Oct 20, 2018 1:48 am    Post subject: Reply with quote
These definitely go on the 'must have' list for a rebuild...
a full set of dogteeth gears.
Me
1981 931, Sabine
2024 KLX300
2024 KLX140
PostPosted: Sat Oct 20, 2018 4:26 am    Post subject: Reply with quote
Gearbox refresh and reinstall the Quaife LSD is on the to do list this Winter. Will need that LSD once the ex Morghen turbo is installed.....
