Front wing removal
newbie924
PostPosted: Sun Oct 14, 2018 1:57 am    Post subject: Front wing removal Reply with quote
I am dismantling a 924 body and , after unbolting all the upper bolts , the 3 underside bolts reach from behind the front spoiler area , a bolt found in the head lamp space and another bolt holding the fender to the bottom sill, the fenders are still hard to remove. Are there any bolts holding the fenders to the body on the door sills by any chance since this is the only area that cant be seen or reached unless the doors are removed.
dubrict
PostPosted: Sun Oct 14, 2018 11:07 am    Post subject: Reply with quote
It sounds to me like you got them all. All the way back deep inside there are 3 bolts attaching the fender to the body right at the door. Their heads are accessible from inside the fender, not the door. Are you sure you got all of those? They're buried in what I like to call "roofing tar" if they've never been removed before, and can be very hard to find.
Likewise, if they've never been removed before, then that roofing tar also has some serious holding power of its own.
1978 924 NA
1979 924 NA
2006 Chevy Impala
2009 Chevy Impala
newbie924
PostPosted: Mon Oct 15, 2018 7:44 pm    Post subject: Reply with quote
I don't think I have unbolted the 3 bolts you mention, but the fender is being held by something holding it at the rear end of it. I thought maybe I had to remove the door which I still have to anyway cause they are needed for my project car. I will try to look or feel for these bolts, Im sure they have undersealing covering them too as the car was well undersealed.
snakoil
PostPosted: Fri Oct 19, 2018 12:26 am    Post subject: Reply with quote
on my 1979 there was this sort of lue/caulking that had dried up with time and made it very hard to remove.
once I had removed all the bolts I had to use an exacto blade to "cut" the caulking and use a flat head screwdriver to pry it apart.
Also note that my car had no inner fenders so instead the entire area was sprayed with some heavy asphalt bed linner material that was very hard to remove. this was also holding back the fender in place
1979 924 NA
newbie924
PostPosted: Mon Oct 29, 2018 2:59 am    Post subject: Reply with quote
I just needed to unbolt the rear 3 bolts mentioned. Now I need to remove it carefully. Thanks/
