curtisr
Joined: 07 Apr 2012 Posts: 98 Location: Kingston, Ontario, Canada
Posted: Tue Sep 04, 2018 9:19 pm Post subject: Transmission making a clunking sound (video) |
The other day I noticed a clunking sound coming from the rear of the car. After determining the whereabouts of the kids and dog, I continued out of the driveway. It was then I noticed that the brake warning light on the consul was on. At first I thought it might be a dislodged e-brake shoe but taking the rotors off ruled that out. The e-brake also appears to be working properly.
The sound comes and goes with speed, coasting, and in neutral.
Here's a video of my turning the half-axle. The car is in neutral (manual transmission).
Any suggestions would be most appreciated. (And, yes, I know it sounds like 'Chain Gang'...)
https://drive.google.com/open?id=1t17YZnCXlmoRHxoeKpcmU33XB7iUedbb _________________ World's worst welder. |
kevingross
Joined: 15 Apr 2015 Posts: 34 Location: Stow, MA, USA
Posted: Wed Oct 10, 2018 10:31 pm Post subject: |
If the sound is coming from inside the transmission, you have either a broken ring and pinion or broken differential, best guess. _________________ Kevin
Catellus Engineering, Inc.
http://www.catellusengineering.com/
catelluseng@gmail.com |
curtisr
Posted: Wed Oct 10, 2018 11:52 pm Post subject: |
kevingross wrote: | If the sound is coming from inside the transmission, you have either a broken ring and pinion or broken differential, best guess. |
Thank you, Kevin. Can you believe that it is so hard in this case to actually figure that out?!  _________________ World's worst welder. |
curtisr
Posted: Wed Oct 10, 2018 11:53 pm Post subject: |
I've decided that I am going to remove the transmission and redo the torque tube and clutch over the winter. This $hould $olve the mystery! _________________ World's worst welder. |
kevingross
Posted: Thu Oct 11, 2018 3:36 am Post subject: |
curtisr wrote: | Thank you, Kevin. Can you believe that it is so hard in this case to actually figure that out?!  |
Well, if you don't fiddle with transmissions all the time, yeah, it could take a little figuring! Let me know if you need help with the transmission. Cheers, _________________ Kevin
curtisr
Posted: Thu Oct 11, 2018 11:59 pm Post subject: |
kevingross wrote: | curtisr wrote: | Thank you, Kevin. Can you believe that it is so hard in this case to actually figure that out?!  |
Well, if you don't fiddle with transmissions all the time, yeah, it could take a little figuring! Let me know if you need help with the transmission. Cheers, |
Promise. Thank you for the most generous offer.  _________________ World's worst welder. |
