Mskeet
Joined: 23 Jun 2018 Posts: 36 Location: Buckinghamshire
Posted: Sun Aug 12, 2018 6:50 pm Post subject: Any advice on an oil leak? |
Hi,
I have a really small oil leak on my UK 1988 924S, I haven't been able to get it up on a ramp yet. Looking form the front of the car, the oil leak seems to be coming from high up on the left near the oil filter, it then runs along the roll bar and drips off from the centre of that. Before I start pulling things apart - would there be an obvious leak point in that location (oil filter aside!). Thanks in advance for any help. _________________ Lover of all things Porsche
1968 912
1988 924S |
16again2009
Posted: Mon Aug 13, 2018 3:24 am Post subject: |
The oil pressure sending unit and the oil cooler gasket were both leaking on mine. They are both in that area. _________________ 1988 porsche 924s
5 speed |
Mskeet
Posted: Mon Aug 13, 2018 5:58 am Post subject: Thanks |
Just worried in case there is a danger it will be spaying back during driving over the belts. _________________ Lover of all things Porsche
1968 912
1988 924S |
Moparboy72
Joined: 29 Jul 2014 Posts: 43 Location: Naperville, IL
Posted: Tue Aug 21, 2018 11:16 am Post subject: |
Maybe the lower balance shaft seal, or balance shaft housing (o-ring) seal are always suspect in my book.
If the leak is very minor, I have used UV dye in the past to help track down the source of a small leak.
Good luck |
Mskeet
Posted: Tue Aug 21, 2018 5:31 pm Post subject: Thanks |
I can get it up on a ramp this week and pin it down. _________________ Lover of all things Porsche
1968 912
1988 924S |
Mskeet
Posted: Fri Aug 31, 2018 8:53 pm Post subject: Thanks for replies |
It was the oil cooler gasket, one on order. _________________ Lover of all things Porsche
1968 912
1988 924S |
Joined: 02 Nov 2002 Posts: 9467 Location: Southeast Wisconsin
Posted: Sat Sep 01, 2018 7:42 am Post subject: |
The oil cooler gasket usually leaks antifreeze. Take a look at the oil cooler section of the shop manual here:
http://www.clarks-garage.com/ _________________ White 87 924S "Ghost"
Mskeet
Posted: Sun Sep 02, 2018 5:14 pm Post subject: Strange |
It is only leaking oil. I have no milky coolant and no throthy oil, so must be oil side only. _________________ Lover of all things Porsche
1968 912
1988 924S |
Mskeet
Posted: Thu Oct 04, 2018 8:29 am Post subject: Problem solved |
It was the oil cooler gasket and the oil pressure sender that were leaking. Both replaced and dry as a bone. _________________ Lover of all things Porsche
1968 912
1988 924S |
